Best way to pull an engine?
So I'm going to pull this motor out to start a rebuild on it and I'm wondering: what's the most efficient/best way to go about doing it? Leave the tranny attached? Leave the front end on? Take off the grill and radiator, etc.?
CAN'T FIX NOTHIN
on these trucks I like to just take the engine out by itself , no need to remove any sheetmetal just the hood , on cars I like to pull tranny and all ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Re: Best way to pull an engine?
remove radiator , battery sometimes battery tray// if there is no work planed on the sheet metal i leave in place// remove hood
me i learned by takin out as a set the motor and tranny// so i am so set in my ways i'd not know how to do it any other way
![]() Join Date: Jul 2013
That depends on what all you are going to do. Just engine refresh then pull rad. then motor only. But if you plan to R&R the tranny also then both together.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
I am a Referee of life.
I always pull together unless the tranny is in great shape.I find it easier to seat the Torque Converter and I usually take the oppourtunity to clean and detail them both.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Aug 2008
A trick when pulling engine only and needing to move the truck is to find a couple of long bolts to go thru the bell housing holes and cut a piece of angle iron as wide as the frame rails for them to sit on. This way you can remove the jack from under the trans, allowing the truck to be moved.
Posted via Mobile Device |
When I did my engine swap I had to pull the trans with the engine; the v8 was in the I6 spot and there wasn't enough room between the engine and firewall to get to the trans bolts.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) ![]() |
