Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-01-2013, 12:38 AM   #1
Sundrop
383 Build
Im planning my 383 stroker build Im gonna be running a 750 Edelbrock carb,Performer Vortex Intake,flat top pistons and some Vortex heads with a compression ratio of 10.86:1 and I have no idea what cam to run in it...I want something with performance and nice hit to it...So guys I need yalls help
Sundrop is offline   Reply With Quote
Old 08-01-2013, 12:43 AM   #2
Sundrop
Re: 383 Build
[/IMG]
Heres my compression test from Summit
Old 08-01-2013, 02:08 AM   #3
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: 383 Build
Call a cam company with all your specs on the engine and the vehicle and they'll recommend something that will work well.
On that note, I'll say that you should run a 650cfm carb at most. You'll be much more happy with the response out of it than what a 750 will provide.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 08-01-2013, 02:26 AM   #4
slowtruck
Re: 383 Build
What fuel are you planning to run? If pump 93 you are going to have problems with iron heads with 10.86:1.
I agree with prostreet on both the calling a cam company and the smaller carb.
slowtruck is offline   Reply With Quote
Old 08-01-2013, 11:25 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 383 Build
"Vortex" heads?? Are talking Gm 96-2000 Vortec iron casting, or is there someone out there making a head called "Vortex"
(Sorry, there is so many new-comers in the aftermarket throwing a name on some Chineese knock-off these days that I just want to make sure I 'm not making an incorrect assumption.
Step one, forget the Edelbroke carb. There nothing but a headache. But do as you will there. Just one opinion.
If this is stock Vortec heads, your limited to .43 lift without doing some work to them. An aftermarket head is typically tolerant of more lift. But again not knowing what you have will just get everyone in trouble.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-01-2013, 12:49 PM   #6
Sundrop
Re: 383 Build
the Vortex heads are from Chevrolet and Ive never had any problems with Edelbrock carbs
Old 08-01-2013, 02:53 PM   #7
gofastnut
gofastnut's Avatar
Re: 383 Build
I think the Edelbrock/holley thing is a lot like Chevy/F***.
I think you're going to run into problems with those heads as far as the max lift you can run. I think detonation may be a problem at 10.86-1, unless you run a cam with enough overlap that it bleeds of some compression, but then it won't run as well.
Maybe look at some THICK head gaskets, or mill the dome off.
Keep us posted on what you do.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 08-01-2013, 03:56 PM   #8
Marv D
Marv D's Avatar
Re: 383 Build
Yeah that would be VorteC, not VorteX. Produced in 1996 -2000 GM truck (L-31) applications. MAX lift is 0.43" as stated. The valve spring retainer hits the top of the valve guide if you try any more lift (destroying the seal and causing all sorts of valve train damage) The press-in studs are notorious for pulling out of the head on the Vortecs, and that is all assuming they are not cracked. The L-31 head was a great head,, 15 years ago. But they were a part of the GM 'less casting is better' (cheaper) being a lightweight thin casting and unfortunately the Vortec is akin to the ancient 'camel hump' heads of the 60's. Just NOT the ideal find they used to be. If you have / find a set, and having them totally rebuilt (assuming they are not hiding cracks between the exhaust seat the the coolant passage) Your going to spend as much on rebuilding them with new valves/ replacing and cutting the guides / springs / seals / milling.. the Aftermarket offers a much better head for less than you will spend 'fixing' a 15 year old used casting.
If your happy with your Edelbrock carb, then you should continue to use it.
I would have to disagree with a couple points gofast...
I've have ran Carter AFB's and Edelbrock 'performer' (simply a Weber produced clone of the AFB that Edelbrock puts their logo on) Yes there is a lot of brand loyality in carbs, but no one winning races is running a Edelbrock carb. They appeal to the "bolt it on and forget it' crowd like showcars and those that dont want to (or know how to) tune the things. I mean seriously,, how many people spend the $69 for the Edelbrock 'calibration kit' and it conveniently leaves BIG gaps in the provided jets and rods so you have to order additional metering rods to 'really' get it right. There pig fat out of the box, and most people are happy with that.
AND increasing gasket thickness to reduce compression on a detonation prone combination is really a BAD idea. He is calling out a 0.015 deck clearance, and a 0.039 gasket is already a 0.044 quench. Real close to the 0.045" quench ( 0.025 stock deck clearance and a 0.020" steel shim gasket). A large qench is a source of detonation to begin with.. Adding quench space by adding gasket thickness is really counter productive to solving the problem of a BAD combination of parts.
That said..
We absolutely agree he's going to have issues with this combination of parts. Too much compression, (just FYI contrary to common terms, Overlap doesn't bleed off compression and there is no pressure built during the intake stroke. It's the late intake valve closing that reduces cylinder pressure at the cost of low RPM torque, but I know what you mean) And trying to find a cam that offers enough duration to that end,,,, and not exceeding his lift limits on stock Vortec's,,, he has a tough ahead of him!!!
But BEFORE the build is the time to discuss things like this... How many have we heard that build with a combination of popular parts from the latest rage in the Chevy magazines,, hen come asking WHY is my motor such a gutless, detonating POS?
Old 08-01-2013, 09:52 PM   #9
Sundrop
Re: 383 Build
That said..
Well Marv D nobody cant argue with that kind of compression cause that can bring serious power to the table I mean I cant argue with a almost 11:1 compression....I was actually hoping for a 10.5:1 ratio with the whole set up but Ill take what I posted above lol...Can you point me in the right direction of things Marv D? So when it comes down to it I'll make sure of no problems
Old 08-01-2013, 10:18 PM   #10
Sundrop
Re: 383 Build
here is the parts the carb,heads,rotating kit so yall can see what Im gonna work with
Old 08-01-2013, 11:09 PM   #11
slowtruck
Re: 383 Build
The problem with that compression on an iron head is you will not be able to just run pump 93 gas. You really need to stay at or just below 10.0:1 for 93 and iron heads, or you are going to need e85 or race gas to keep the motor out of detonation.
Old 08-01-2013, 11:14 PM   #12
Sundrop
Re: 383 Build
well then...would it work with alumnium heads?
Old 08-02-2013, 09:23 AM   #13
T Smith
T Smith's Avatar
Re: 383 Build
I would definitely step up to a better head, not that much more $$ right now and greatly improve your build, I'd go aluminum with intake runners around 190-195.
T Smith is offline   Reply With Quote
Old 08-02-2013, 06:46 PM   #14
msgdsrf
Re: 383 Build
I just went through all this on my new 383 which will be on the chasis dyno Tuesday (Woohoo!).
Typical cam specs for similar 383s will have about 280 adv/230 @ .050 and will then have lift about .45-.55.
If you want a good "hit", you want good torque. So I believe it's best to think in terms of air velocity instead volume of air at max RPMs. I'd rethink the carb size for certain and consider a well designed head with runners 180-190cc. You have some mismatching bits there with a 750cfm carb into 170cc head runners.
BTW, I'm at a calculated 11:1 running 91 pump gas w/ full timing and no predetonation. The rest of the numbers on Tuesday.
msgdsrf is offline   Reply With Quote
Old 08-06-2013, 10:22 PM   #15
78c10 sleeper
Re: 383 Build
Imo I would go with a 750 carb (4150) holley but that's just me. Also I would stick with around 10.5 compression max just to be on the safe side.
78c10 sleeper is offline   Reply With Quote
Old 08-07-2013, 11:08 AM   #16
Marv D
Marv D's Avatar
Re: 383 Build
Have any report for us on how things went onthe dyno?
Old 08-07-2013, 04:14 PM   #17
slowtruck
Re: 383 Build
How much power do you really think a 11.0:1 motor will make over a 10.0:1 motor on pump gas? Also I'm not trying to be rude but does it sound like Sundrop needs to be messing with that to get so little?
I have an 11.0:1 383 going into my 67 and it will be on e85 because its easy to get around my house and pump 93 I feel I would need to run a little rich and a little less timing to keep out of predetonation.
Old 08-09-2013, 01:59 AM   #18
Sundrop
Re: 383 Build
What do you mean by "but does it sound like Sundrop needs to be messing with that to get so little?" Im not trying to sound dumb I just cant wrap my head around it
Old 08-09-2013, 07:04 AM   #19
Marv D
Marv D's Avatar
Re: 383 Build
What he is saying is the power difference between 10:1 and 11:1 on a street vehicle is beyond the point of diminishing returns. If you get an extra 10-20 honest HP and have to run $10 a gallon VP C-12race fuel,,, is it really worth it? Cost per mile to drive becomes measured in $'s per mile not ¢.
Been there, My 66 I originally built as a 12.5:1 383, solid roller, custom AFR's bla bla,, 580HP motor. Would start it up, warm it up, drive 1.5 miles to the store, buy a $1.99 loaf of bread, take a back road home so I cold stick my foot in it just to proove to myself I could shread those stupid 17" Hoosiers,, pull in the drive and I had burned over 2.5 gallons of (at that time) $9 a gallon C-12. Cost me $22 to go buy a $1.99 loaf of bread.
It get's old fast and your hot rod sits more and more and more until it's not hardly driven at all. Mine went back to a 9.25:1 pump gas motor and got DRIVEN! In fact in that configuration it wone me more money at the track then the 9 second Nova.
But no one could convince me it wasn't a good idea at the time.... some of us just have to learn lessons on our own.
Old 08-09-2013, 10:36 AM   #20
msgdsrf
Re: 383 Build
Well, It was not a specific goal on my 383 to acheive 11:1, it's the way things came together. Compression itself doesn't add so much but it can make a build work better (i.e. cam).
We ended up spending too much time tracking a misfire (thanks to exhaust guy for breaking plugs) and haven't got everything out of it yet. Carb is dialed but I think the ignition curve could be better. Torque at the rear wheels was very flat, 305 ftlbs. at 3750 (275 from 3000). I have a few hundred miles on the engine, heat wave, traffic and even a load to the dump (That truck doesn't belong here...). No detonation (12.7 air to fuel, full timing, 91 octane pump gas), runs great.
Old 08-09-2013, 11:50 PM   #21
Captainfab
60-66 Nut
Re: 383 Build
If you don't mind, could we get some more info on your engine build that allows you to run the 11-1 static compression?
Old 08-10-2013, 02:27 PM   #22
gofastnut
gofastnut's Avatar
Re: 383 Build
That said..
Thanks for setting it straight Marv!
As far as Ededbrocks go, I don't really like them, and I agree they're for the "slap it on and go" crowd, and the "tuning kit" stinks!
You also put into order the fragmented thoughts I had about "bleeding off" compression. I had forgotten about quench.
I'm curious to see how this is going to turn out.
Jeff
C-10 Club
Old 08-10-2013, 03:18 PM   #23
msgdsrf
Re: 383 Build
Nothing real special. I would say the cam intake closing at 67 ABDC keeps cylinder preasures where is runs well (and it really does). Does that take away low end, well not if you have the compression to begin with I'd say.
OEM Roller block .03 over, .015 deck (Yes, I would have perfered zero deck)
Cast 3.75 crank
Flat top Hyper w Moly comp ring
.039 gasket (x4.166 as spec'd by AFR)
AFR 180 street ported, 63cc
Compcams XR282HR-10
1.6 Rockers
Performer Air Gap
Speed Demon 650 Vacuum, Jets .07/.104, 6.5PV (@12.7AFR)
TH400 w/2600 stall, 3.73 gears and 29" tires
I have only limited experience with SBCs but have modified enough Thumpers and Twins to get a handle on four strokes. From the bike world I've always considered cylinder cranking pressure as the measure of how it might operate. Static Compression is only one factor towards what cylinder pressure will be and that is ultimately what will determine how easily compression contributes to detonation, IMHO. Then you have volumetric efficiency, cylinder heat, intake charge temps, and...
Old 08-11-2013, 12:30 AM   #24
Captainfab
60-66 Nut
Re: 383 Build
Thank You
Cast 3.75 crank
Compcams XR282HR-10
1.6 Rockers
Performer Air Gap
Old 08-11-2013, 02:53 AM   #25
Super73
Super73's Avatar
Re: 383 Build
Marv and I agree on most things right Marv
I run an Edelbrock 1406 on my 462" Lincoln and it runs simply awesome out of the box. And I don't plan on changing it.
But I also run a 12.9 compression motor on 91 octane when cruising around and e85 when putting my foot in it. Given it is not a traditional small block.
I do believe tighter quench is good to a point(.040" is about all I'd run), sometimes though reducing the efficiency will aid when you are creating a very efficient combo IE a power adder like N20. I run my N20 stuf a little looser than that.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
