08-04-2013, 07:53 PM | #1 |
New steering wheel
It wasn't much fun trying to get the old steering wheel off until I bought the right tool for the job. One thing for sure I had to custom engineer the Grant horn assembly parts because they just wouldn't work.
1970 C-10 350, 350 trans, ps,pb |
08-04-2013, 08:31 PM | #2 |
Re: New steering wheel
Good looking wheel. Where did you get it? I need one and I like the looks of that one.
08-04-2013, 08:36 PM | #3 |
The grant adapter parts really do suck.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
08-04-2013, 08:56 PM | #4 |
I found this one on Ebay. I tried the parts houses for old Chevy trucks but this same one was always out of stock.
08-04-2013, 09:20 PM | #5 |
I just installed a Grant 969 w/ the blue bowtie today,i reamed the hub assembly with a cylindrical grinding stone from home depot.The install kit is 3126,and I picked it up at pep boys.Now the first one I tried to intall on my 67 column didn't go so well so I bought a Flamming River column from pick-um-up (Frank) for a really good price ,and it came with a FR horn contact.The only thing I had to do was change the horn contact connector.It works perfect.
84 step side 87 swb |
08-04-2013, 11:39 PM | #6 |
If there was a "Like" button on this forum i'd use it on your post!
Grant Horn hardware just bites, the fiber disk wears out and the assy pulls apart and the horn goes off all on its own, even in the middle of the night......
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-05-2013, 01:15 AM | #7 |
Guess I better mount some kind of "make and break" switch under the hood in case that happens to mine. Doesn't seem like that fiber disc has to move much unless you have to lay on the horn a lot. I noticed though that the fiber near one of the shoulder bolts was already starting to crack just from shipping. Grrrrr
08-05-2013, 04:57 AM | #8 |
It's alsways something.....
Burgie, that looks really sharp!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
08-05-2013, 07:30 AM | #9 |
Thank you!
08-05-2013, 08:45 AM | #10 |
I put in a Flaming River column this weekend with their adapter and horn contact. I still have the Grant fiber disk and horn button, and I had to re-drill the steering wheel for it to line up right. But it is 300% of the Grant design.
08-05-2013, 08:54 AM | #11 |
I got the same wheel and like it a lot. I bought mine off of amazon for a fraction of the cost at other places. I am finding amazon to have many parts with free shipping. Good for things like bumpers which are next on my list.
I was unable to get the horn to work on mine at all. I agree the parts do suck. Looks great!!! |
08-05-2013, 07:53 PM | #12 | |
08-05-2013, 08:15 PM | #13 |
what tool did you use to get the old hub bit off?
08-05-2013, 08:25 PM | #14 |
what puller did you use to get the wheel off? i've tried one i borrowed and have bent the bolts on the puller, that go into the wheel, and no luck with it coming off.
08-05-2013, 08:40 PM | #15 | |
http://www.harborfreight.com/46-piec...set-69889.html The only problem with this puller is that the yoke or whatever you call it has 4 slots. You have to use the two slots opposite of each other and it won't quite fit so you have to take a round file or die grinder and remove about 1/32 of an inch on both slots towards where the large jack screw is. Once I did that and used some of their longer bolts in the kit it popped right off. Although at first when it came free I freaked out thinking that I broke or stripped something but it was just coming loose on the steering shaft.
10-11-2014, 10:46 AM | #16 | |
From what I've read it looks great and the wheel and your truck certainly do. The thread will be a good reference for me when I'm replacing my wheel. Your old one looks like mine now , cracked a bit different though
You can't spell Olive without Love 1970 C-20 350 V-8 Daily Driver |
10-11-2014, 10:50 AM | #17 |
Nice new wheel and truck.
Your old wheel reminds me how old steering wheels are like ghettos... Looks like about the same sh!t, just different crack locations.
10-11-2014, 11:31 AM | #18 | |
lol!!!!!
10-11-2014, 05:49 PM | #19 |
have the same wheel, love it but no horn , so off it comes
10-12-2014, 09:13 AM | #20 |
Old member
The easy way to stop the horn is to just unplug it. It's just a slip on connection on the front of the drivers side wheel well.
10-12-2014, 09:19 AM | #21 |
looks good!
