Old 08-09-2013, 10:48 PM   #1
Stepside Man
Stepside Man's Avatar
1986 Dana 60 help.
While tearing down my Dana 60 on my 86 1 ton GMC i came across some parts I need to replace. The problem is that this part is not on any of the exploded diagrams and I need to know what it is and where i could get another one.
Delco still makes the backing plates and I have a part # for them. This piece does not come with the backing plate.
This is like a dust shield and slides on after the backing plate. My Dana 44 has the backing plate and this piece as one casting.
Any help would be appreciated.
Steve.
1977 K10 6ft Stepside L6
1978 C10 8ft Stepside 400
1980 C10 8ft Widebox with Uncle L6
1986 K35 Not a dually 350; 79 K20 Stripped
1973 and 1976 Chevy Truck Trailers
1995 Impala SS LT1
Stepside Man is offline   Reply With Quote
Old 08-10-2013, 07:00 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: 1986 Dana 60 help.
That looks like a dust shield without the surround. Group 5.002 part 463813 and 462814
is what the GM parts book shows.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 08-10-2013, 07:13 AM   #3
Stepside Man
Those are the number for the dust shield. What this does is it goes on on top of the dust shield.
Those part numbers are not for this.
1995 Impala SS LT1
Old 08-10-2013, 09:37 AM   #4
GM72K10
Next!
GM72K10's Avatar
Just had one of my trucks apart for calipers rotors and pads, it didn't have what you're looking for.
86 K30 CUCV M1028A1
Old 08-10-2013, 09:46 AM   #5
1968vetL-71
Junior Member
1968vetL-71's Avatar
Step side man, I am in the middle of COMPLETELY rebuilding my Dana 60 and one of those shields on mine is corroded also. I'm on the hunt for some and when I find anything out ill let ya know.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 08-10-2013, 10:20 AM   #6
russgt
russgt's Avatar
http://www.pirate4x4.com/forum/newbi...a-60-ring.html
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-10-2013, 10:31 AM   #7
Stepside Man
That pirate link tells me nothing. I know what they do, I took them off. What I need to know is where to get new ones. And I am apparently not alone.
1995 Impala SS LT1
Old 08-10-2013, 10:35 AM   #8
russgt
russgt's Avatar
google.com
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 08-10-2013, 11:14 AM   #9
chengny
chengny's Avatar
lmgtfy_com.htm
chengny is offline   Reply With Quote
Old 08-10-2013, 11:30 AM   #10
Stepside Man
Originally Posted by chengny View Post
lmgtfy_com.htm
That does nothing.
1995 Impala SS LT1
Old 08-10-2013, 12:23 PM   #11
chengny
chengny's Avatar
Mud slinger maybe? Aftermarket available only as a press-on fit:
$2.50 per at:
https://www.4wdfactory.com/store/pro...2C-Mud-slinger
Old 08-10-2013, 12:34 PM   #12
Stepside Man
$2.50 per at:
Those look nothing like what I have pictured. Totally different part.
1995 Impala SS LT1
Old 08-10-2013, 12:48 PM   #13
chengny
chengny's Avatar
Part number 56:
Old 08-10-2013, 01:36 PM   #14
Stepside Man
I have seen that exploded view before. The location of that piece is incorrect in the drawing. It does not go between the spindle and the knuckle. It actually belongs between 63 and 64. It is also facing the wrong direction. That part number i believe starts 1400XXXXX. I could not find any info when I googled it.
1995 Impala SS LT1
Old 08-10-2013, 02:29 PM   #15
russgt
russgt's Avatar
http://www.billavista.com/tech/Artic...nt_Axle_Bible/
part way down the page CHEVY DANA 60 exploded view
#56
PN# doesnt seem to come up as the right part though
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 08-10-2013, 03:06 PM   #16
russgt
russgt's Avatar
http://coloradok5.com/forums/showthread.php?t=283576
Call Boyce equipment, they stock them.
http://www.boyceequipment.com/
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 08-10-2013, 04:11 PM   #17
Stepside Man
Now we are talking!!!!
Exactly right. I will call them Monday.
1995 Impala SS LT1
Old 08-11-2013, 01:11 PM   #18
Stepside Man
If anyone else has any idea where to get these that would be great.
1995 Impala SS LT1
Old 08-13-2013, 09:23 PM   #19
russgt
russgt's Avatar
What did boyce have to say?
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 08-13-2013, 09:40 PM   #20
Stepside Man
Boyce does not have any. Back to square one.
1995 Impala SS LT1
Old 08-17-2013, 08:40 AM   #21
Stepside Man
Anyone else have any ideas on this?
1995 Impala SS LT1
Old 08-17-2013, 09:53 AM   #22
speedmachine
ive seen them alot worse, do a little repair job... cut out a strip and weld it on, if you cant weld use shallow rivets.. just an option.
speedmachine is offline   Reply With Quote
Old 08-17-2013, 04:32 PM   #23
GM72K10
Next!
GM72K10's Avatar
http://hillbillywizard.com/
Give them a shot, you never know
86 K30 CUCV M1028A1
Old 08-18-2013, 11:19 AM   #24
LONGHAIR
I wonder why the exploded view is so wrong? Nothing goes on before the spindle.......plus it's backward. Makes no sense?
In reality though, you could just leave them off. It really only "slightly" blocks debris from getting behind the hub. It is not a "seal" or sealing surface, so mud and water can still get in there.
I wouldn't worry about it.....and I sure would not go to great expense to get them.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-18-2013, 11:49 AM   #25
dieseldawg142
dieseldawg142's Avatar
agreed. did a 10.5 Sterling swap on my boss's 03 s. duty, shields were mostly rotted away, left them off. this is on the rear axle of a work truck that goes to the pit (messy mudhole) 5 times a week. no problems, in fact they stay alot cleaner without them...
dieseldawg142 is offline   Reply With Quote
1 ton axles, dana 60
