08-12-2013, 12:12 AM | #1 |
dana 44 spindle question
Hi are the front dana 44 4wd spindles the same for disc and drum.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
08-13-2013, 07:33 PM | #2 |
Re: dana 44 spindle question
ttt
08-13-2013, 08:39 PM | #3 |
Not per the Chevy parts manual. Group 6.020 seems to cover both the knuckle/spindle unit and the spindle alone. Sorry I just don't know much about D44 interchange.
Might try digging through the Dana publication X510-8 http://www2.dana.com/pdf/X510-8DSD.pdf Quad 4x4 is another good place to look. http://www.quad4x4.com/gm44F8boltclo...1960-1969.html http://www.quad4x4.com/gm44fHDclosed...1962-1969.html http://www.quad4x4.com/gm44front1968-1972.html http://www.quad4x4.com/gm44f1973-1981.html
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-03-2015, 10:04 PM | #4 |
Can someone expand this info please?
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
07-04-2015, 01:10 AM | #5 |
Depends on the year of the 44 with discs. and the weight rating. What are we working with?
07-04-2015, 08:22 AM | #6 |
The spindles are all specific and don't swap. The knuckles not as much. But, what is weird in that GM parts book is it shows 69 and 70 as using the same knuckle when '69 is closed and '70 is open
07-04-2015, 02:31 PM | #7 |
D44tech has a lot of good information
http://d44tech.com/69-72_front.html http://d44tech.com/Front_axle.html
07-04-2015, 10:11 PM | #8 |
I want to put front disc brakes on a 1970 K10.
07-04-2015, 10:23 PM | #9 |
Looks like my best bet is to find a 71/72 complete front axle.
07-04-2015, 10:34 PM | #10 |
All about them K’s
73-87 front axle should bolt right in as well and should be easy to find
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
07-05-2015, 08:16 AM | #11 |
The '70 Dana44 is a perfect candidate for a disc brake swap using disc brake Dana44 knuckles-out. The perfect donor axle would be one with a torn up differential, bent or broken housing, bad carrier bearings, etc. Otherwise, just a total axle swap and save the '70 for parts
07-05-2015, 07:45 PM | #12 |
So, did some 73 to 87's have the Dana 44?
07-05-2015, 09:23 PM | #13 |
All about them K’s
Yes sir up to the mid 70s if I recall correctly(I'm thinking 77ish) the gm 10 bolt that finished up thru 87 after the 44 phased out is nearly identical to the 44.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 07-05-2015 at 09:48 PM. |
