08-23-2013, 05:39 PM | #1 |
Four Core & Three Core Rad. Mounts F/S
One pair of 4 core upper rad mounts. No rubbers or nut plates but glass beaded, primed and painted semi-gloss black. $20 shipped
One pair of 2 & 3 core upper rad mounts. Nice rubber cushions with nut plates included. Glass beaded, primed and painted semi-gloss black. $ 25 shipped Money order only, do not have a Paypal account. Please reply in thread.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
08-23-2013, 10:34 PM | #2 |
Re: Four Core & Three Core Rad. Mounts F/S
Silly question, what measurement would be needed to see if a radiator was a 3 or 4 core radiator? I need a set of these but the replacment radiator I got was free, but the PO didn't know 3 or 4 cores. If some one on here could tell me one way or the other I'll buy a set.
88Ironduke |
08-23-2013, 10:48 PM | #3 |
Since changing to a 4 core radiator I can get you those dimensions tomorrow but did not keep the 3 core as it was rotted out. Sold it for scrap. Surely someone has them, maybe check with your local parts house if they have a 3 core in stock?
Went to the shop and looked at my '71 4x4 radiator. Measured just the cores not the retainer ridges on the tanks. 4 core radiator mearures at 2 5/8 " thick. Alfter doing that I did a SEARCH from the board using "radiator diferances" and " radiator thickness " in the SEARCH window and found this from another member: 4 Core thickness = 2 5/8" 3 Core thickness = 2" 2 Core thickness = 1 1/4 " The 2 and 3 core radiators use the same mounts while the 4 core radiator uses a mount all of it's own. Hope that is some help to you.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 08-24-2013 at 05:44 PM. Reason: Added info |
08-24-2013, 10:45 AM | #4 |
ttt bump
08-24-2013, 02:06 PM | #5 |
Thanks. I'll be heading to the shop tomorrow so I can get good measurements.
88 |
08-24-2013, 05:45 PM | #6 |
88Ironduke, please re-read my previous post. My fingers don't always type what my brain is thinking, LOL. The 2 core radiator is 1 1/4" thick.
08-24-2013, 05:56 PM | #7 |
what are nut plates?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
08-24-2013, 07:30 PM | #8 |
Probably not the " correct " term for them but it's what I call them. The small tin plates with a mounting hole that fits the shroud end of the radiator support upper bracket. The shroud bolt/screw fits into it when mounting the radiator/shroud together. Two required, one for each upper rad support. Common to both sizes of rad mounts. Most likely could be had at a parts house or hardware store
Any body know what the real "true" name for them is, LOL ?
08-26-2013, 07:34 AM | #9 |
a still have these bump
09-02-2013, 11:32 AM | #10 |
ttt one last time
09-02-2013, 12:19 PM | #11 |
I take the 4 cores for $20 shipped. PM me.
Thanks Jim |
09-02-2013, 01:19 PM | #12 |
FOUR CORE mounts SOLD TO JimH2828 PM sent with payment info.
The 2 & 3 core rad. mounts still available.
09-06-2013, 06:40 PM | #13 |
Payment received and 4 core upper mounts shipped. Thanks, JimH2828
2 & 3 core upper mounts with rubber cushions still available. Blasted, primed and painted $25 to your door.
