08-24-2013, 05:31 PM | #1 |
Clips that hold fender splash shields in
On my 66 there are two pieces of metal with rubber stapled to them that connect with these little twist clips to hold them perpendicular to the fender. You see the metal pieces when you open your door and you see the rubber stapled to them.
Does anyone know where you can find them? I tried searching here and google and haven't found them, checked a few common vendors' websites, etc. Any help would be appreciated.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
08-25-2013, 07:21 AM | #2 |
Re: Clips that hold fender splash shields in
08-25-2013, 12:16 PM | #3 |
I bought those and they are not the same, they are smaller. might work if you drilled new smaller holes.
1961 chevy K10 my build is------------61K10 build |
08-25-2013, 12:42 PM | #4 |
It at least helps to see what they're correctly called now, now i can search around!
Mine are pretty small already...crazy those would be even smaller. Also, that shows enough for two fenders but i recall mine had two panels held with those type clips, so you'd need 6 per fender if i remember right.
08-25-2013, 12:45 PM | #5 |
61K10, did you find anything else that does fit?
08-25-2013, 01:01 PM | #6 |
Here's another thread about them, classic ones look the same?
http://67-72chevytrucks.com/vboard/s...d.php?t=562292 http://www.classicparts.com/1960-66-.../#.Uho4Nhukq2Z And also a dead ebay link. I will use the classic ones, thanks for the info guys!
08-25-2013, 01:11 PM | #7 |
Literally 30 seconds too late, just ordered them from classic, wanted to get it done before heading back out to the garage to do some easy stuff today.
If the classic ones are too small, i'll get a hold of 456, thank you for the tip!
08-25-2013, 01:34 PM | #8 |
the holes in my fender brace and seal piece are 5/16" the one's they sent me are like 1/8"
post up when you get yours from classic. sense my truck isn't a total stock restore i will probably pop rivet or use self tapers. would like to know what they send you though.
09-04-2013, 08:25 PM | #9 |
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
10-01-2013, 08:25 PM | #10 |
They worked grey, just put them in, squeeze the head and the bottom opened up and held very snug.
