Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 09-21-2013, 03:09 AM   #1
hipasschev94
hipasschev94's Avatar
93 k1500 build
this is the start of my long going project (still thinking of a name..) it is a 93 k1500 ext cab with a 350 bored .60 over and cammed, 4" suspension lift and 3" body lift on 35/12.50 R15 wheels. the first pictures are of as it sits now all cleaned up not yet showing what ive done to it. when i first got the truck it needed some brake work and had a few hidden suprises. everything ive had to do so far is rotors, driver side front brake line off of the T, wheel hub, cv axles, full fuel system clean, full tune up and a tranny flush and filter change.
<><JP><>
hipasschev94 is offline   Reply With Quote
Old 09-21-2013, 03:11 AM   #2
hipasschev94
Re: 93 k1500 build
this would be the interior, i love how nicely it cleaned up
<><JP><>
Old 09-21-2013, 03:19 AM   #3
hipasschev94
Re: 93 k1500 build
now the things ive done to it, i re did the whole stereo besides the coax speakers, new pioneer head unit with a rear usb, a boss riot series 2 channel 600w amp thats powering 2 boss d10 10" subs in a under seat sealed down fire box with a poly fill, then ive also wired in a usb power hub to be able to charge my ecig, then i put a oem 79' hood embelem on from my old 88. almost forgot to post pictures of the motor so here those are as well
<><JP><>
Old 09-21-2013, 03:20 AM   #4
hipasschev94
Re: 93 k1500 build
last picture of the motor for now
<><JP><>
Old 09-21-2013, 03:23 AM   #5
hipasschev94
Re: 93 k1500 build
you dont get this everyday off of a craigslist buy, when i was organizing the glove box and manufactures book, i found 3 very nice things to have the original of the gm lot brand new window sticker, the trucks warrenty pamphlet, and the warrenty card on the dealer tires as well
<><JP><>
Old 09-21-2013, 03:36 AM   #6
hipasschev94
Re: 93 k1500 build
now what my plans are for it. a rcx 6" suspension lift, torsion bar relocator (if i can still get them) keep the body lift, build a mild 355, rebuild the 4L60E with a shift kit, go through everything else and refurbish (front and rear diffs, and transfer case) under coat everything, fix the body rust, im not sure on a full exterior color yet but i want to re paint and re dye the interior black with brush aluminum accents. theres a few more things i just dont fully re call them off the top of my head right now
<><JP><>
Old 09-28-2013, 07:56 PM   #7
Mickeymotormount
Mickeymotormount's Avatar
Re: 93 k1500 build
Some day I would like to do something with mine. I'm experiencing some frame rust and cab rust.
An upgrade I did that you may want to investigate is the LS engine transplant. My truck never ran so good. It gets better mileage too. Something to think about.
John
1967 C20 2WD Longbed
2001 2500 HD 4X4 Extended cab long bed
Mickeymotormount is offline   Reply With Quote
Old 09-29-2013, 12:02 AM   #8
hipasschev94
Re: 93 k1500 build
ill defanitly look into it, im still going round on what the new heart will be. the frame was one of the fist things i had to look at on this truck with me wanting to do the SAS because on mine and my dads 88 k1500 the frames were pretty bad so it took them off the list :/ my old 88 was so bad my frame actually snapped
<><JP><>
Old 09-29-2013, 12:03 AM   #9
hipasschev94
Re: 93 k1500 build
wow sorry i just re read this and theres a few thing off from what the final plans are, ill figure out how to get the full refined list on soon
<><JP><>
Old 09-29-2013, 12:11 AM   #10
hipasschev94
Re: 93 k1500 build
alright im glad that worked.. but heres where im at as far as plans, this is just a rough idea and everything will be refined as i get further along
Suspension/Drivetrain
SAS swap
Corporate 10/Dana 44 front and rear (73-87 k10 donor)
Dual shock hoops
NP208 pass. Drop transfer case
Dual steering stabalizers
Rear shackle flip?
7-8” net lift
35-37” tires (mickey Thompson baja claws)
Refurbish American racing hot wheel rims
Fresh built 350 bored .60 over mild cam (tbi or carb?)
Hooker long tube headers
True dual straight pipe exhaust/ Cherry bomb glass packs
4L60E trans/TH400 with B&M shift kit
Rhino line frame/axles/under body/engine bay
Chrome/Stainless steel accents
Dual rear shocks
Ladder bars?
Exterior/Body
Lighted visor
Razor back
2-4” Cowl hood
Nerf bars
Bed rails
Rhino lined bed
Diamond plate tail gate cover
Reflective window tint
Dark metallic gun metal silver/black
Accented pin striping
Interior
Re-dyed fabrics black (seats/headliner/carpet/door panels)
Brushed aluminum trim/accenting
3 gauge A-pillar cluster (oil pressure/trans. Temp/?)
<><JP><>
