Old 09-26-2013, 04:40 PM   #1
shopteacher
1967 3/4 ton Cummins GMC
Well after looking at all of these great looking Chevy and GMC pickups for years I thought it was about time I started on mine.
I had a 67 GMC 25 years ago and selling it was a sad day for me, so I found a 3/4 ton fleetside 67 GMC in pretty original condition and decided it would be a great 2WD Cummins diesel conversion.
First I stripped and power washed the inside and disassembled to not only check it out, but to prep for body work and paint! Plus it is nice to have stuff out of the way for the cummins conversion.
I bought a 1993 Dodge 1 ton for the engine (165K) and automatic overdrive transmission. The bad part is I used the engine in another conversion, a 1999 Ford Super Duty that my son and I did.
Well I started tearing it down and cutting 12 Inches out of the frame to make it a short wheel base. I had a Sterling rear end that I had from a F250 with a 7.3 IDI that went under the rear.
I had drum breaks on the front so I traded some parts for a 1977 Chevy 3/4 ton disk brake front end, so about 16 bolts later out with the old and in with the newer, along with that came a power steering box to round out the front end.
shopteacher is offline   Reply With Quote
Old 09-26-2013, 04:42 PM   #2
shopteacher
Re: 1967 3/4 ton Cummins GMC
Ooooops here is some pictures first to start the thread!
Old 09-26-2013, 04:49 PM   #3
Saclandman
Saclandman's Avatar
Very cool. Should be a fun project.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 09-26-2013, 05:07 PM   #4
shopteacher
Tear down and frame chop !!!
Old 09-26-2013, 05:10 PM   #5
shopteacher
The only Rust it has is on both rocker panels and on the inside panels !!! The doors, fenders and cab ends are real clean along with all the glass.
Old 09-26-2013, 05:19 PM   #6
shopteacher
I'm using a Sterling 10.25 rear end from a F250 diesel application and I will be regearing it to a 3 .07 ratio.
The transmission is an overdrive with a manual lock up from the 93 Dodge 1 ton 2WD and as soon as I get the block back from the machine shop the mock up will start!
Old 03-24-2014, 09:05 PM   #7
shopteacher
Well I made some engine mounts and mocked up the engine in and out a couple of times ! Tomorrow I will add the auto trans and start hooking things up! Not to forget to paint the frame and reroute some brake lines and other stuff!
I also have to do some removal of part of my front frame brace!
Old 03-24-2014, 09:51 PM   #8
seth7843
seth7843's Avatar
Looks like a great project. I would love to do a cummins swap on my 67' in the future. Do you plan to box/reinforce the frame at all?
seth7843 is offline   Reply With Quote
Old 03-24-2014, 10:33 PM   #9
70blackfish
KOOL keep the pictures coming
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 03-25-2014, 12:04 AM   #10
Maxxd07
Maxxd07's Avatar
Count me in on this one.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 03-25-2014, 12:22 AM   #11
shopteacher
I boxed in about 12 inches of the frame where the motor mounts brackets were welded into the frame! It is a 3/4 ton frame to begin with so it should be stout enough!
Old 09-08-2014, 10:05 AM   #12
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
subscribed! like the engine color too
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-08-2014, 03:41 PM   #13
Tinkermc
Lookin good
Tinkermc is offline   Reply With Quote
Old 09-08-2014, 10:35 PM   #14
CorDog009
Subscribing. Looks like a cool project.
CorDog009 is offline   Reply With Quote
Old 12-18-2017, 08:59 PM   #15
Catman36
Catman36 is offline   Reply With Quote
Old 12-18-2017, 09:01 PM   #16
Catman36
Just starting the same build on a 69 c -20. How did your project end up. Any help would be appreciated. Only difference is I’m wanting to put a 5.9 common rail and a auto trans.
