Old 09-29-2013, 05:30 PM   #1
Thebrownturd
Rust in upper window seal
I live on a dirt road and once you hit the washboards in the road the truck gets to boncing it starts to rain rust in my lap. I am very sure the rust is mostly because of the water getting under the cab lights. Not a surprise sence I think the truck spent most of its life in Washington. Anyway does any one know what to do once I get around to replacing the window seal. I can't do anything major but I need to stop the rust before the window falls on me.
Thebrownturd is offline   Reply With Quote
Old 09-29-2013, 06:07 PM   #2
airdale94
airdale94's Avatar
Re: Rust in upper window seal
The roof drip rail is also a source for leakage also. Once it's rusted it turns into major. You can scape (chip) the putty out of the drip rails and re-putty. And wire brush the winshield lip and coat with a encapsulator then reseal. Or you can do what I did and get 100% pure silicone clear caulk (Home Depot) and seal everything up.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-29-2013, 10:09 PM   #3
Thebrownturd
I have resealed the drip rail and there was no rust there. It only seems to be rusty in the window seal
