09-29-2013, 06:16 PM | #1 |
driveshaft help
I've got a 71 swb c10 with a 350/350. I don't have a driveshaft for it. Well, I have one out of a 6 cyl 3 speed. The front shaft on that driveshaft doesn't fit my transmission. Could I swap out the front yoke for one off of an automatic driveshaft?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
09-29-2013, 07:18 PM | #2 | |
Re: driveshaft help
http://www.iedls.com/ I used to live in Orlando and Advance Driveline on Carder road is a good place I have used. |
09-29-2013, 08:29 PM | #3 |
Re: driveshaft help
So if I find a turbo 350 driveshaft I could swap out the yoke, and then have it cut to length?
09-29-2013, 09:23 PM | #4 |
Re: driveshaft help
You won't need a turbo 350 driveshft IF yours is longer than you need to connect your new trans to the diff. . The driveshaft shop will put your shaft in a lathe, cut off the trans end with a parting tool and install a new yoke that fits your trans and rebalance the shaft. It'll cost about 50.00 for the TH350 yoke (it's a spicer 30 I think) and the machine time to get the shaft to the correct length. Shouldn't cost much over $150.00
09-29-2013, 09:29 PM | #5 |
Re: driveshaft help
ok, thanks!
09-29-2013, 10:39 PM | #6 |
Re: driveshaft help
Depending on whT tran the 3 speed is i used the 3 speed yoke on my 71 in my th350 then again in my 4l60e slid right in on all of them
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-29-2013, 11:07 PM | #7 |
Re: driveshaft help
hmmm... Mine doesn't fit in my TH350.
09-29-2013, 11:55 PM | #8 |
Re: driveshaft help
Go to junk yard and find drive shaft out of a Chevy truck with a 350/350 combo. And yes the three speed yoke fits a th350. I have the two piece driveline from a three speed and it had a th350 on it.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
