Old 10-03-2013, 07:13 AM   #1
Kawtoom
HELP me identify V8 in my 69 please.
Just bought a '69 c20. Originally came with 396, was told it has a 350(?) now.
Can't find anything online when entering numbers from the block, except one site that said it was a 283 from the late 50's...?!?!
Any pro's out there that can help me figure this out, I'd really appreciate it.
V073IDE
Kawtoom is offline   Reply With Quote
Old 10-03-2013, 08:06 AM   #2
RANZTRANZ
Re: HELP me identify V8 in my 69 please.
Help us help you...how about finding the casting number off the block, normally it is on the back side of the block behind the driver side head...also while you are cleaning that area you may find the actual casting date...both of these can be found but you may have to spend a bit of time hunting for them...post the numbers once you find them or goggle them and I am sure you will find you answer.
RANZTRANZ is offline   Reply With Quote
Old 10-03-2013, 09:39 AM   #3
geezer#99
geezer#99's Avatar
Look here.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-4.php
If it's a 58 or 62 283 it will have a road draft tube beside the distributor as a telltale sign.
Old 10-03-2013, 01:18 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
DE could also be a *****in' 307!
Get the casting number off the back of the block like mentioned earlier. There will probably be a half inch of crud on top of it... so you'll need to scrape it off to see it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-03-2013, 02:36 PM   #5
RANZTRANZ
Just for starters, The V = Flint Plant, 07= July, 03 = 3rd date of the Month.
A fire cracker block I see....so far...
Old 10-03-2013, 03:07 PM   #6
geezer#99
geezer#99's Avatar
Get your bifocals cleaned Ranz! LOL!!
It's 0731 July 31st.
Old 10-03-2013, 04:35 PM   #7
RANZTRANZ
ahhhh, dang...all I see is a "I" after the 3. is it that Math where you carry the one over or something like that ? but there is not any three letter engine codes like IDE... that is with the glasses on tooo ...LOL!!!!
Old 10-03-2013, 04:41 PM   #8
RANZTRANZ
OK...I am thinking its a 68 307 or a 58 283.....I do see a 8 (snowman) on that pad somewhere...
Old 10-03-2013, 05:32 PM   #9
geezer#99
geezer#99's Avatar
That '8' doesn't indicate year. THat first number is part of the serial number on the truck. However there should be a 3 digit code behind the pass head and the last digit indicates the year.
Old 10-03-2013, 06:49 PM   #10
RANZTRANZ
Maybe look like F 7 8....f =June maybe G=July 7=day 8=year (1968) which if we had the casting number we could put this all to bed...Good Night.
Old 10-03-2013, 11:03 PM   #11
Captainfab
60-66 Nut
That is definitely an "I" between the 3 and the D, but I think that it was used in place of a 1 for some reason.......might have been at 4:55 on Friday.
I see what appears to be a power pack head, so my quess would be a 283. A '68 307 would have had heads with the accessory holes. Of course all of this is assuming the heads weren't changed at some point.
Old 10-04-2013, 11:36 AM   #12
GASoline71
GASoline71's Avatar
Good eye Cap'n!
Gary
Old 10-04-2013, 08:39 PM   #13
68gmsee
Active Member
68gmsee's Avatar
Kawtoom, where are you? Did you just post one post and leave?
By the way, welcome to the site. Do respond with more info. There's other numbers on the side of the block and maybe behind the drivers side head that will help identify this engine.
I do know that in some GM engines, like Corvettes, the last few digits of vin number were stamped on the pad. I have one on an engine stand right now.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
block, engine, motor, numbers
