Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-07-2013, 03:11 PM   #1
In The Ten Ring
$150.00 to rent a welder
Well....back to the broken bolt fix. I don't have 220 volts in my garage. A friend is a custom welder and will be up my way next month. He says he'll do it, even use his rods, if I get a welder.
I just checked with a rental place and they have a Bobcat with its own generator and will rent it to me all weekend for $150.00. So...that's the plan to fix this:
Thoughts? Comments?
In The Ten Ring is offline   Reply With Quote
Old 10-07-2013, 03:19 PM   #2
jorgensensc
jorgensensc's Avatar
Re: $150.00 to rent a welder
Where is that bolt at? There has to be a cheaper/easier way. Why can't you just drill it out?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-07-2013, 05:09 PM   #3
DGulliver
DGulliver's Avatar
Yeah, a decent electric drill and about 4 good bits...20 minutes and she's out!
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8
'74 Trans Am 400, '80 Trans Am Indy Pace Car
Mercedes AMG S55, SLK230 Kompressor, GL450
'96 Dodge Indy Ram Official Indy Truck
'99 Porsche 911 Carrera
DGulliver is offline   Reply With Quote
Old 10-07-2013, 05:31 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Looks like one of the center seatbelt bolts on DS? Looks like it's plenty big enough to drill it out and use and easy out bit???
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-07-2013, 07:06 PM   #5
DWilbur
You can buy a 110 volt welder at Harbor Freight for about $100. they work good. I have a plasma cutter from harbor Freight and it works great.
DWilbur is offline   Reply With Quote
Old 10-07-2013, 07:33 PM   #6
arturo7
arturo7's Avatar
Check out your local craigslist as well.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 10-07-2013, 11:34 PM   #7
cableguy0
You say rods meaning stick welder I assume. A stick welder isn't going to work at least not very easily The rod itself will be too thick to do what you need to do. I would not spend 150 bucks to get out one broken bolt. Another 2-300 bucks gets you a pretty decent 110v mig welder. You will find plenty of other uses for it especially with an old truck. Whatever you get make sure it uses gas and not just a basic flux core welder. Flux wire for sheetmetal or body work sucks.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-08-2013, 02:22 AM   #8
In The Ten Ring
It's one of the bolts that hold in the cab gas tank. Head came off when I was removing the tank.
I tried an easy out but I botched the job! Oh well, it was my first time.
I'm taking a welding class next semester and I think I'll just hold off on that bolt. It isn't essential and I can just remove the seat and gas tank and get it out later. My dad is a master welder but he's too elderly for that sort of thing now. A good friend is a welder also but I don't have 220 volts in my garage.
So I may just wait till next summer.
Oh yes, my dad agrees that I can just drill it out, after I smash what's left of the extractor I broke off! LOL
Old 10-08-2013, 07:22 AM   #9
cdowns
cdowns's Avatar
a wader is not the way to fix that/// just a real good way to screw things up even more
get somebody who has a drill and buy reverse twist drill bits drill out and at worst you just need to slightly tap the hole slightly over sized // a not cruitical thing like the really is not needed all that much anyway so size doesnt really matter all that much
too bad you were not closer/// i'd fix it up for $145.99
Old 10-08-2013, 03:37 PM   #10
_Ogre
_Ogre's Avatar
for 2 times that rental you could buy a lincoln wire welder from home depot
shop air compressor timer
Old 10-08-2013, 04:28 PM   #11
DWilbur
I'm talking wire fed welder at Harbor Freight for about $100.00. all you have to do is add pressure regulator for the argon gas. my brother bought one and it works for thinner materials.
Old 10-08-2013, 05:42 PM   #12
team39763
Tractor supply also has a $100 JobSmart welder.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 10-19-2013, 07:14 PM   #13
Mr. 250r
Mr. 250r's Avatar
Drill the center out with a smaller drill bit and get an e-z out bit we break bolts all the time at work and use e-z outs without them we'd have hundreds of more hours into everything
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-19-2013, 11:40 PM   #14
ERASER5
ERASER5's Avatar
Look and read. He did drill the bolt. He did use an easy out. He broke it off. You can see the stub in the picture. However, a stick welder is not the right tool.
Try hitting the easy out stub with a center punch. That may be what you implied. Once the stub is broken, drill bigger. Do you have a propane torch? I like Mapp gas myself. Heat that bad boy up! If you must weld a std onto the bolt, use a MIG or better, a TIG. Good luck.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-20-2013, 12:13 AM   #15
71swb4x4
71swb4x4's Avatar
Saying you need to rent a bobcat generator/welder to take a bolt out is a lot like saying you need to rent a backhoe to plant your garden. Way overkill for what you need. If you want to weld a nut on it, rent a 110 volt welder. They will do everything you need them to do. I have a 100 volt Hobart Handler 140 and I have used it to get broken bolts out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-20-2013, 02:23 AM   #16
mikey2409
quick fix if you have a electric dryer that run 220 volts you might need a adapter to plug in but im saying you dont cause 220 plugs are just like 110 they a basic standard design even though they are different
mikey2409 is offline   Reply With Quote
Old 10-24-2013, 09:35 AM   #17
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=
I'm taking a welding class next semester [/QUOTE]
Very Wise!
Tom Vogel is offline   Reply With Quote
Old 10-29-2013, 08:50 PM   #18
Tinkermc
for that money I would not rent but own.
Tinkermc is offline   Reply With Quote
