10-15-2013, 09:47 AM | #1 |
WTB: 1970 date coded 402 BB Intake
Hey guys - My 70 CST 402 truck had an aluminum intake put on it at some point, and another previous owner switched it out to a semi-correct 71 or 72 402 intake, but the choke boss is in a different orientation on a 70 intake, plus this is the only not date code correct part on my truck now, so I want to swap it to someone who has a late 69 or 1970 dated intake and needs mine, or buy one outright - does anyone happen to have a verifiable correct 1970 402 BB intake to sell?
10-24-2013, 02:16 AM | #2 |
Re: WTB: 1970 date coded 402 BB Intake
Btt
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
10-24-2013, 10:25 AM | #3 |
Florida Edition
PM sent
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
10-24-2013, 11:12 AM | #4 |
Proprietor of Dale's Corner
I just found this...I have a few manifolds at home I will look if you're still lookin'
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
10-24-2013, 12:10 PM | #5 |
wanna be 67
Which intake are you looking for?
3963569 1970 402 aluminum with Holley 4BBL low rise intake. riveted oil splash shield. 3955287 1970 402 cast iron with Rochester 4BBL low rise intake. No oil splash shield. |
10-25-2013, 11:07 AM | #6 |
Ole' Blue & 19Step - after talking to JQ-72 on this forum about this, his suggestion to me was to ask for a Mar/April/May date coded 1970 intake, to be consistent with my trucks' May build month and match the trucks' other March & April date codes - so if either of you discover a 70 intake with these months on it, please let me know - Thank you so much!
10-25-2013, 03:25 PM | #7 |
"Trucks with Class"
I have a complete 70 402 truck engine. The intake casting number looks like: #3956287. It is hard to read, so the "6" may be a "5". Anyway, I am sure it is a correct '70. The build date is "J 23".
10-27-2013, 12:10 AM | #8 | |
Just in case anyone out there thinks I am insane for being so granular on the date code, I want to just say I normally never care too much about date codes as long as my trucks are "correct" parts-wise, but this particular truck is so untouched minus someones understandable decision many years back to slap on an Aluminum intake and headers, that now that I have corrected the headers issue by replacing them with the correct 402 exhaust manifolds, I only need to get this one last thing right then the truck will be so much more valuable and a correct historical example as well, so hopefully someone out there has one closer to my build month, so until then I will keep looking....thank you!
