Old 10-16-2013, 08:05 PM   #1
Dustytrix
02 sensor help
I have a harness that came with the flat 4 pin 02 sensor connector. The problem is that its a male connector, also all the 02 sensors I have seen have male connectors too. What am I missing here? The harness came off a 01 chevy truck with a 4l80e trans if that helps. Can I get an coupling or just buy the female connecter? Thanks
Dustytrix is offline   Reply With Quote
Old 10-16-2013, 08:56 PM   #2
71chevystep4x4
71chevystep4x4's Avatar
Re: 02 sensor help
That's just how they are, mines the same and its a 99. O2 sensors do come with female plugs.
71chevystep4x4 is offline   Reply With Quote
Old 10-16-2013, 09:28 PM   #3
Dustytrix
Re: 02 sensor help
Thanks I didn't realize that, yea I found the sensor I think will work bosch 13027 it has the female end.
Old 10-17-2013, 02:44 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 02 sensor help
I had mine setup for the "all purpose" upstream 02 sensor with heater circuit. The Bosch 13444 runs the square 4 pin connector instead of the model specific style. They are fairly cheap as well, just something to keep in mind if your making your own harness.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-05-2014, 04:12 PM   #5
DjS71
Re: 02 sensor help
I'm going to resurrect this thread to ask a follow up question. My harness guy put the flat four connectors on my harness instead of the stock 4 square ones. (REFERENCE) I don't mind getting new sensors, in fact, its probably a good idea anyway.
So, True or False: The sensors in question, Bosch 13026 Bosch 13026 (matches my harness) instead of the OE styled Bosch 13474 Bosch 13474 will provide the same info to the PCM but are terminated with different connectors.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
