Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 11-03-2013, 01:28 PM   #1
85/Silverado
85/Silverado's Avatar
Paint Finish Help
From what I think happened my Painter didn't use a foam polish wheel to finish off the paint job. So all I need to do is the 3rd step of a paint job?
Get Perfect It Swirl Mark Remover and the Foam Pad to get a nice finish then put a couple good coats of some kind of car wax on it?
I just bought a Dewalt Polisher DWP849X 600-3500 rpm var. speed.
If you look close at the photo you can see the lack of a shine esp. right below the bright area where the light is reflecting.
85/Silverado is offline   Reply With Quote
Old 11-03-2013, 07:14 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Paint Finish Help
I would consider some 2000 or 2500 grit wet and dry sanding paper and a rubber backing piece to get the paint smoother before doing the buffing step. Many body shops truy to match the factory finish that believe it or not has a certain amount of orange peel in it's finish. If you want it to shine, be prepared to buff the whole vehicle to get it to all match. I would also ask the body shop just how much clear coat that they put on, so that you don't overdue the polishing and rub through to the basecoat.
Frank
piecesparts is offline   Reply With Quote
