Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 11-20-2013, 06:03 AM   #1
OARNGESI
OARNGESI's Avatar
tempature gauge problems
hi i got a 08 sierra with a v6, and every couple days the gauge stops working the check engine light comes on and my gauge reads engine hot ac turned off. if you reset the light the gauge starts working then a day or two later it does the same, we changed the sensor and there was no change anyone know what this could be?
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 12-07-2013, 01:47 AM   #2
mag68
mag68's Avatar
Re: tempature gauge problems
It's probably a failing thermostat. I know that sounds stupid and ironic but it's just the way the computer works and tries to protect itself. If your motor is truly not overheating and the temp sensor is not bad, it probably is the thermostat opening too early. Often the motor is actually too cool, not too hot. (long story I don't feel like typing). Anyway, for < than $10 bucks you should be good to go again. You will also need to reset the code by disconnecting the negative battery lead for a minute or two. I'm pretty confident this will fix your issue.
1976 Chevy 454 C-10 Silverado
2004 GMC Sierra 5.3L 1/2 Ton Crew Cab
1968 Camaro SS RS
mag68 is offline   Reply With Quote
Old 12-08-2013, 08:01 AM   #3
OARNGESI
OARNGESI's Avatar
yeah I swapped in a new one and topped off the water about aweek ago.
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 12-08-2013, 10:33 PM   #4
crunchyg
Oarngesi, did replacing the thermostat fix the problem? If not, we can try a couple of other things.
crunchyg is offline   Reply With Quote
Old 12-09-2013, 07:48 AM   #5
OARNGESI
OARNGESI's Avatar
it seems good for now thanks
70 SWB STEPSIDE
70 BLAZER
09 challenger
