Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 11-21-2013, 11:49 AM   #1
Dale99
Lift question on 08
I purchased my truck used, it already had the lift blocks at the bottom of the strut assy. I am wanting to change my lift and wanting to know about how much I have now. If the block is about 1.25-1.5 thick, thats around a 2 to 2.5 lift correct?
My rear has about 1.5" blocks, but looks like the front is higher.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 11-21-2013, 11:45 PM   #2
rhd_c10
rhd_c10's Avatar
Re: Lift question on 08
thats correct .. thats how i leveled my truck before i did a full 6" procomp lift
my rhd build.. http://67-72chevytrucks.com/vboard/s...d.php?t=468712
1964 CHEVROLET BISCAYNE 350CI/TH-350
1968 CHEVROLET C-10 SWB LS1/4L60E
rhd_c10 is offline   Reply With Quote
Old 11-24-2013, 02:49 AM   #3
l79m20
There is probably a plate on top of the strut also. You will only be able to see it with the strut unbolted and lowered down. The front will be lifted a total of 2.5 and the rear is only lifted an inch.
l79m20 is offline   Reply With Quote
Old 11-24-2013, 09:50 AM   #4
Dale99
Ive replaced the front struts, I have nothing up there right now. That's what I want to go to is all lift above the strut, so I can put a drop differential kit on it and help with my driveshaft angle.
