Old 11-30-2013, 05:17 PM   #1
ChevyGearHeads
Driveshaft heartache
I got my 350 turbo in my '68 LWB and the damn driveshaft was too long...wondering which route to take now? kind of hit a roadblock
ChevyGearHeads is offline   Reply With Quote
Old 11-30-2013, 05:40 PM   #2
midniteblues
midniteblues's Avatar
Re: Driveshaft heartache
I have a lwb 2 pc drive shaft here if its what you need.
it came from a 71 lwb 292/t350 truck
if you can use it you can have it
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-30-2013, 06:54 PM   #3
ChevyGearHeads
I am actually in MD, I have moved since making this account...but thank you very much for the offer
Old 11-30-2013, 07:07 PM   #4
midniteblues
just tryin too help
sounds like you need a trip too the driveshaft shorting shop
Old 11-30-2013, 07:24 PM   #5
cdowns
cdowns's Avatar
checkout local driveline shop new ujoints carrier bearing and shortening with balancing might jus b cost effective
Old 11-30-2013, 07:53 PM   #6
ChevyGearHeads
I was wondering if a 70's or '80's driveshaft would work? anyone know?
Old 11-30-2013, 10:01 PM   #7
chiefcfd
chiefcfd's Avatar
What did you replace? Does your th350 have a 6 or 9 inch tailshaft. A th350 w/6 inch tailshaft is the same length as the 3 speed manual.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 11-30-2013, 10:20 PM   #8
marvgarr68
marvgarr68's Avatar
Take a measurement and hit the junk yard take the trans yoke so you can find a shaft with right u joints. This is what I did I went one piece a lot better.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 11-30-2013, 10:52 PM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
Shorten and ballance isn't too expensive. Neither is having a one piece built. Take it to a real driveline shop, plenty of people can make a driveshaft shorter, few can do the job correctly.
If you want to spend a bunch of time and money you can search junkyards, then pay to have that shaft fixed.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-01-2013, 01:12 AM   #10
marvgarr68
marvgarr68's Avatar
Why would you be spending more money getting a one peice drive line at a junk yard? All the junk yards I have been to have a pile of drive shafts find one the right length and u joint size. Took me a whole 15 mins to find mine was in perfect shape cost a whole $20.00. Then you go buy two u joints which are around $10.00 a piece and install them reuse the original trans yoke and all is done. All this for about 2 hours total and about $50.00 with taxes.
1968 chevy fleetside, driveshaft
