Old 12-01-2013, 07:42 PM   #1
Brave71
Ac firewall holes
This really sounds crazy to me but.. My 72 has original holes for factory ac in the firewall but no vent holes for ac in dash? It does not look like the firewall has been changed .. Seems like it would be alot of work to change ? Any one ever see something like this?
Brave71 is offline   Reply With Quote
Old 12-01-2013, 07:56 PM   #2
JimKshortstep4x4
Re: Ac firewall holes
Since there is not a lot of difference in the firewall holes is it possible that you are looking at the standard heater holes? Here is a picture of a firewall with the hole patterns of both systems labeled.
Another possibility is that someone changed out the dash.
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-01-2013, 08:14 PM   #3
Brave71
Thanks for the pics.it's got the ac holes just like in the picture.. Doesn't look like dash was changed and if it was it would have been nice if they would have put in an ac dash! There is about an inch and 1/8 space for the wire loom . Should it be that wide?
Old 12-02-2013, 12:42 PM   #4
JimKshortstep4x4
I am not sure what you mean by the space for the wireloom. Can you clarify?
If the dash is changed correctly you may not be able to tell since the spot welds are under the windshield seal and the sides are bolted in.
Jim
Old 12-02-2013, 06:29 PM   #5
gysgtc
Are you talking about the cowl to hood seal area? 1 1/8"
gysgtc is offline   Reply With Quote
Old 12-02-2013, 06:31 PM   #6
gysgtc
Sorry. Where the wire loom is it is about 1 and 1/8 inch. Just measured mine.
