Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-04-2013, 07:48 PM   #1
slinginrods
slinginrods's Avatar
Lowered and towing
Any body on here lowered and towing?im thinking about lowering my 12 cc 2wd with a 5 ,7 kit but I tow a car hauler for my race car and hot rod.i also have a 17 ft boat I tow .any body doin this?
slinginrods is offline   Reply With Quote
Old 01-07-2014, 06:21 PM   #2
creep
Registered Loser
creep's Avatar
Re: Lowered and towing
It can be done. I don't know the specifics but I'm sure it depends on the kit. You could also install helper air bags to level the truck when a trailer is attached. A friend of mine tows with his bagged crew cab dually with no problems whatsoever.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 01-16-2014, 08:04 AM   #3
BigBlocksRule
^ helper bags and you'll be fine, seen it done plenty of times.
BigBlocksRule is offline   Reply With Quote
Old 01-17-2014, 10:36 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
If you go with helper bags, you will find that there a lot of brake lines and other items attached to the rear axle that will have to be moved. I started with Air Lift brand bags and finally settled on the McGaughys bag kit for my 2011 GMC. They mount out where the lines are not an issue. I have my truck dropped 5/7
Frank
piecesparts is offline   Reply With Quote
Old 02-26-2014, 07:44 PM   #5
GWEE
GWEE's Avatar
When i had my 08 crewcab i had a McGaughrys 4/7 drop w/Helpers on 24swith 275/30 and towed my car hauler with my 72 Camaro with no problems.
1985 GMC ( future plan pro tour build for the wife )
Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST
rules
GWEE is offline   Reply With Quote
