Old 12-05-2013, 04:11 PM   #1
ksshane
ksshane's Avatar
CL Bucket Seats - Not mine
Ive been looking for a pair of bucket seats for my truck, and came across these on CL. He is asking 400 for them which is a bit more than I want to spend on seats right now.
I normally post in the truck section, but these buckets are actually out of a blazer so I thought someone here might be need them
http://wichita.craigslist.org/pts/4190642278.html
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 12-05-2013, 09:51 PM   #2
71jimmy
71jimmy's Avatar
Re: CL Bucket Seats - Not mine
Nice find, those buckets are out of a '73 up, the tracks won't quite fit in the '72 or earlier.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 12-09-2013, 03:52 PM   #3
rayray767
71 jimmy,
How can you tell if they are out of a 73 and up thanks
rayray767 is offline   Reply With Quote
Old 12-10-2013, 12:22 AM   #4
71jimmy
71jimmy's Avatar
The difference in shape is subtle, but would be clear if you had a true 69-72 seat next to them. The seat back is more rounded on top than these. Also, the seat covers are definitely not the earlier style, '73 up had that emblem in the center of the seat backs.
I've heard that you can put the earlier seat covers on these with minor foam trimming. But the driver seat track will not line up with the factory holes if I remember, the passenger seat track/tilt will work.
Old 12-10-2013, 01:13 AM   #5
rayray767
Thanks for that info
Old 12-11-2013, 04:53 PM   #6
Chulisohombre
Chulisohombre's Avatar
I have the later style Passenger seat In my 72. The front bolts 3/4 line up. The rear is the same bolts but it needs risers on the rear or the seat will Be laid way back because the rear isn't raised there on a first gen blazer. I put in a aluminum spacer and longer bolts to Make It sit better. Still Need mod the bracket so all the bolts go In on the front.
Chulisohombre is offline   Reply With Quote
