Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-06-2013, 08:08 PM   #1
olblue1970
olblue1970's Avatar
70 c10 Headlights Problem
Hope someone can help me figure this out. Recently, my right passenger side headlight stopped working. I bought a replacement bulb and installed it, but it only works on low beam. The high beam won't work. The left bulb continues work on both settings. I checked the new bulb, and it's designed for both low and high beam settings. I read some earlier threads on here about similar situations, and some said the problem might be the floor mounted headlight dimmer switch. Mine definitely has its issues. Sometimes, when shifting between low and high beams, the lights go out altogether, and the red high beam indicator light on the dash doesn't show. Perhaps that's it.
Any thoughts appreciated.
Thanks!
Ol' Blue 1970
Ol' Blue 1970
aka The Blue Widow
1970 Chevy C10 350v8 - 700r4 - 3.73 rear differential
http://67-72chevytrucks.com/vboard/s...d.php?t=566713
olblue1970 is offline   Reply With Quote
Old 12-06-2013, 08:13 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 70 c10 Headlights Problem
Check the ground at the light. if it were the switch both low or high would be out. Also check that the new bulb is good. put it in the other side. Then replace the dimmer because it should never turn off the lights.
dwcsr is offline   Reply With Quote
Old 12-07-2013, 05:02 PM   #3
JJLT1
JJLT1's Avatar
dimmer switch first, sounds like its bad..
check connections on the hi beam wire to the pass light, see if it has voltage..
never hurts to check/clean grounds..
add a relay> http://madelectrical.com/electricalt...adlights.shtml
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
70 c10, dimmer switch, headlights, high beam, won't work
