Manual Throttle Complete 71/72
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Manual Throttle Complete 71/72
Do you have the manual throttle pedal? Same pedal as small block? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
The gas pedal that it mounts on?! If yes, I do! lmk
Carpe manana
Hmmm, tempting....can you post a pic of the gas pedal? I thought BB pedals differed from SB gas pedals but I may be completely wrong. Thanks! Pete
I wiill get you pics tomorrow.
Moderator
![]() Join Date: May 2007
Adam- if you have the pedal for this, and Pete passes I'll take it. It's about the only thing not on my dash, lol.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Carpe manana
I'll pass to Scott - this is more of a want for a possible project rather than a need. Thanks though! Pete
there right there is piece missing ( but the peddles are not deferent)
I got 69-70 one and have it on standard bar (off another truck) and seen the 71-72 |
Moderator
Adam- I believe there were two different pedals used based on my research. Do you have the bracket that the mounting tab attaches to? It should look like the one pictured here: http://67-72chevytrucks.com/vboard/s....php?p=5105934
The other pedal I have seen looks like this: http://67-72chevytrucks.com/vboard/s....php?p=5960858. It looks like the mounting tab attaches to the assembly itself without the additional bracket used on the other pedal setup. The manual cable attaches right next to the regular cable without the additional welded-on bracket. I do not know if the cables used were different lengths or not?
Moderator
Here is one Livrat sold with the same pedal you have, but a different bracket than the one Sharpie sold?? http://67-72chevytrucks.com/vboard/s....php?p=4030205
I guess there is some bracket though for the tab to mount to??
I have it all...I will go get it together and post some more pics for ya
