Old 12-17-2013, 05:01 PM   #1
shultzee13
99 C1500 Suburban P0420 code
How do I determine which oxygen sensor to replace on this truck? It seems like it has left and right upstream downstream..... Jeez.
Anyway to know which one?
Thanks.
shultzee13 is offline   Reply With Quote
Old 12-17-2013, 05:07 PM   #2
bighaas79
Re: 99 C1500 Suburban P0420 code
All the p0420 or p0430 codes I have ever dealt with have always been bad cat. But 420 would be bank 1, 430 would be bank 2. And you would be looking at down stream for cat monitoring codes.
bighaas79 is offline   Reply With Quote
Old 12-27-2013, 12:21 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
P0420; low catalyst efficiency bank 1
bank one is the driver's side. Every single time I've seen a 420/430 it has been a bat cat. Aftermarkets only last 2 years at best unless you spend the big bucks for one with plenty of precious metals in it (dealer)
find cause for cat going bad before throwing $600/cat at the truck.
also watch the bank 2 sensors to see how far that one is from dying.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
