Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-19-2013, 10:17 AM   #1
Riley012
Radio
I have a after market radio in my 82 chev k20. It does not put out a lot of volume, could this be a ground problem or do I need to replace the radio. Thanks for any help.
Riley012 is offline   Reply With Quote
Old 12-19-2013, 12:16 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Radio
It's hard to answer with so little information. Is this just something off the shelf, plugged into the stock harness with an adapter or something?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 12-19-2013, 12:17 PM   #3
panhandler62
Java Mechanic
Re: Radio
I'm going to bump this over to the audio area where it will get more of the right attention.
Keith
Old 12-21-2013, 09:08 AM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Radio
Depending on the radio. Is it stock radio, aftermarket what brand.
Most factory radio are in the 20-40 watt range which as stated are low volume.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-13-2014, 06:40 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Radio
need a type/model,but some older older ones, the speaker ground and the radio power ground had to be @ same chassis ground
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-02-2014, 02:08 PM   #6
nekkidhillbilly
Re: Radio
older one im sure doesnt put out alot of power. some of the ones from the 80s put out about 5 watts per channel. i remember having one that put out about 10 per channel and that was alot then.
nekkidhillbilly is offline   Reply With Quote
Old 03-02-2014, 04:39 PM   #7
1970/327/c10
1970/327/c10's Avatar
Re: Radio
Some aftermarket radios, don't have pre amps in because they just send it through the factory amp on new vehicles. One example is Power accoustic, sounds good in a new vehicle but would suck in are because no factory amp. I have a JVC and its a good brand and puts out a lot of sound for a reasonable price.
Drivin People Insane With my Classic Chevy!
1970/327/c10 is offline   Reply With Quote
Old 03-03-2014, 11:45 AM   #8
nekkidhillbilly
Re: Radio
not a jvc fan had a few had better luck with pioneers kenwoods alpines and clarions.
