Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 12-22-2013, 02:27 AM   #1
augwld
wipers
I have a 1979 k10 cheyenne,as far as I can find. The wipers only worked on high with a delay switch,when I bought her. I put in an '82 switch from bone yard and all was good. For a year. Pump quit working 5 months ago, and auto park went out 3 months later, but otherwise working.What's the problem here? My buddy's 1976 motor has 2 wire plugs, as well as my 1986, but my '79 has 3. Hunting for a new switch, I am asked if it has intermittent wipers, but I don't know. Can anyone help me get this figured out? Is it the switch or the motor? I have a junk 1991 s10. Can any of those parts work?
augwld is offline   Reply With Quote
Old 03-13-2016, 08:55 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: wipers
I have a 1979 k10 Cheyenne, as far as I can find. The wipers only worked on high with a delay switch,when
You answered your question: intermittent wipers are the same a delay
But you can not mix match delay switch & none delay motors with Delay Motor & none delay switch.
Because it may not work or work right.
with the Parking since you change so much. If arm are in the place but not returning Ground is bad from motor to fire wall or cam is wore out
LINK: http://bowtieguy.proboards.com/threa...-washer-repair
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
