Old 12-22-2013, 02:05 PM   #1
tismy55
Rear Leaf Spring Question
Is there a certain position the rear leaf spring has to go to be installed ? Also How is pinion adjusted ? Thanks
tismy55 is offline   Reply With Quote
Old 12-23-2013, 01:16 PM   #2
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Re: Rear Leaf Spring Question
we need more info on your set up. 4wd? pinion angle adjustment i assume? what are you looking to achive? are all good starting questions.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 12-23-2013, 01:40 PM   #3
tismy55
what would the stock pinion angle be ? like 10 degrees or less,, and the springs have a clamp on one end holding the leafs together does it matter if that clamp faces forward of the rear housing or behind the rear housing.Thanks
Old 12-23-2013, 03:27 PM   #4
cleszkie
cleszkie's Avatar
The centering pin on lift springs will not be centered between the spring eyes. The 6 and 4 inch lift springs that I have used have had the centering pin located a tad closer to the front spring eye. I don't know if this is the case for a stock leaf pack.
If you are running a rear driveshaft without a CV joint, the angle needs to be split evenly between the transfer case yoke end and axle yoke end. The transfer case output shaft and axle pinion must be be parallel. If you are running a CV joint at the transfer case end of your driveshaft, you need to make the angle at the axle yoke about 0 degrees (can give up to 2 degrees to account for axle wrap under acceleration) while pointing the drieshaft directly at the transfercase yoke and put all of the angle into the CV joint. Follow these guidlines to position your spring perches on your axle before welding, or to shim your existing perches and you will have good results. Good luck.
cleszkie is offline   Reply With Quote
Old 12-23-2013, 03:30 PM   #5
tismy55
Thank you very much Thats what I needed to know.
Old 12-23-2013, 10:45 PM   #6
tismy55
This leaf spring is what I was talking about does this clip holder go in that direction i installed mine and it doesn't fit the bracket I reversed it and it works but I had to force it over to mount into the rear shackle. I had to use this picture for reference.
Old 12-24-2013, 11:56 PM   #7
Chulisohombre
Chulisohombre's Avatar
On lift springs you want the longer side front to push the axle back a lil bit. Should center the axle better. Driveshaft should be within 2 degrees of the tranfer case output. Usually 2 degree negative to help angles under spring wrap
On acceleration.
Chulisohombre is offline   Reply With Quote
Old 12-27-2013, 02:25 PM   #8
tismy55
I measured the springs they are 26-26 from center to center which would be the longer side ? Thanks
Old 12-27-2013, 05:16 PM   #9
Chulisohombre
Most are offset two inches to help center the axle. The two pairs I've had we're. I guess yours are not set that way. If it had shims on the spring the fatter side goes to the rear to tilt the pinion up. You have lift springs or stock?
Old 12-27-2013, 05:35 PM   #10
tismy55
just like these in this picture this one picture shows the leaf spring holder at the front mine goes toward the rear. can the springs be used on either side? Thanks
Old 12-27-2013, 05:44 PM   #11
Chulisohombre
If these are yours they look backwards. The shim should be bigger end to the rear. I believe on mine the military wrap that holds the springs is To The rear as well. Which also leads me to that your springs are Backwards. They can go on either way as both spring eye bushings have the same size bolt hole.
Old 12-27-2013, 06:30 PM   #12
tismy55
If your wrap is at the rear then mine are correct. I just didn't know I just seen this one and thought that was correct.
Old 12-27-2013, 06:56 PM   #13
tismy55
I looked online at 72 blazer rolling frames and everyone had the wraps toward the front ? well i'm back to square one again
Old 12-27-2013, 08:37 PM   #14
Chulisohombre
Ill look tomorrow but mine have it on both sides I believe. You didn't answer are these lift springs or not? Do they have a shim in the spring pack or a lift block?
Old 12-27-2013, 08:43 PM   #15
Chulisohombre
The springs in the picture you put are backwards. Or at least the lift block is. Every truck is going to be slightly different. If the axle is centered on the spring you should be ok. Just check the ujoint angles and make sure the pinion is pointed slightly at the transfer case.
Old 12-27-2013, 08:43 PM   #16
tismy55
they are stock,, I was just using this pic it is not mine.
Old 12-27-2013, 08:47 PM   #17
Chulisohombre
I haven't had stock springs in years. I'll do a lil research and see if I can find my stock pics.
Old 12-27-2013, 09:15 PM   #18
Chulisohombre
Did some looking around. Seems to be stock springs have the wrap to the front and lift springs have it to the rear. Four four or five of each for comparison.
Old 12-28-2013, 03:59 PM   #19
tismy55
Will a 73 blazer 4x4 rear leaf spring fit my 72 perches ? They are the same length.
Old 12-28-2013, 08:40 PM   #20
Chulisohombre
I believe both are 2.5 inch wide springs and are similar in arch and length.
Old 12-28-2013, 09:22 PM   #21
tismy55
I installed the springs from a 73 blazer but they don't fit the axle perches seem to be about 3/4"- 1" off . I mounted the springs in the hangers then raised the axle to meet the springs, then I did it reverse mounted the springs to the axle would not connect to hangers. I am lost now
Old 12-28-2013, 09:57 PM   #22
Chulisohombre
Measure the width. Should be 2.5 inch wide. They should sit flush with the spring perches. Then the spring plates should have the ubolts flat against the spring perches to either side. If that's not the case then you may have the wrong springs. Did you replace the perches? Pics at this point of what uou have would help a lot.
Old 12-28-2013, 10:00 PM   #23
Chulisohombre
I always mount the springs first then lift the axle up to the springs. It's easier to maneuver that way.
Old 12-28-2013, 10:11 PM   #24
tismy55
can you tell me the width of your axle perches center eye to center eye. I may have wrong rear end?
Old 12-28-2013, 10:16 PM   #25
Chulisohombre
I'm not at my truck but I have a one ton 1978 rear in mine now. The 73 and up axles 1/2 and 3/4 ton are 1.5-2 inches wider between the perches than the 69-72.
