Old 12-27-2013, 10:14 PM   #1
Chevytruck10
1950 Chevy Truck S-10 frame Motor
I am putting my 1950 Chevy Truck onto a 1980's S-10 longbed truck. I picked up a chevy 350 out of a 1973 Camaro to put in the truck and wanted recommendations on a manual transmission. Does anyone have experience doing this swap or with a similar setup?
Chevytruck10 is offline   Reply With Quote
Old 12-28-2013, 11:34 PM   #2
D-man313
D-man313's Avatar
Re: 1950 Chevy Truck S-10 frame Motor
I did one. Used a 350/350 combo though.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 12-28-2013, 11:58 PM   #3
Chevytruck10
What did you do for motor mounts?
Old 12-29-2013, 10:03 PM   #4
Atommik
Atommik's Avatar
I used a 327 with th350 for my swap. For motor mounts I used S10 mounts for the 4.3 6 cyl that was available for the S-10. Bolted right up to my 327. After fitting the motor/trans where I wanted it in engine compartment, I tack welded the mounts to the frame, lifted the motor out and finished the welding. Then reinstalled the motor/trans. Really not too difficult. I'm sure using a manual trans would be about the same.
Atommik is offline   Reply With Quote
1950 chevy truck, 350, manual transmission, sbc
