12-28-2013, 01:37 AM | #1 |
Popping noises in reverse
I've noticed this past year that I get a lot of popping and binding when I'm in reverse. So far it's only when I'm towing the pop up or boat. It doesn't do it any other time. Ol' Yeller has a 4" lift and 33's with the stock drivetrain. Any ideas?
12-28-2013, 08:18 AM | #2 |
Re: Popping noises in reverse
Self adjusting brakes maybe?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-29-2013, 12:32 PM | #3 |
U joints worn out or worn out spider gears in the diff or weak pressure disks in the posi rear. If so equipped. Self adjusting brakes if loose can pop when changing direction if they aren't adjusting on their own. I adjust mine every few months because of this.
