Old 12-30-2013, 10:13 PM   #1
cppursell
cppursell's Avatar
Unhappy Big Leak trouble, Help! Video of oil leak
Hey truckers,
I've been living with a bad oil leak on my 307 for a while now, at the front of the oil pan where it meets the timing cover. Last night I removed the oil pan by raising the engine, cleaned and scraped thoroughly, then installed a nice one-piece silicone gasket and tightened up the bolts not-too-snug. The dang engine leaks the same! Please watch this video and evaluate, Where is the leak coming from, out of the timing chain cover? Is the U-bend of the oil pan not snugging up (but it didn't leak this bad before)? Thanks for your help!
cppursell is offline   Reply With Quote
Old 12-30-2013, 10:48 PM   #2
truckdude239
truckdude239's Avatar
Re: Big Leak trouble, Help! Video of oil leak
Depending on he pan it could be warped. But also there are 2 different gaskets a thin gasket and a thick gasket most 75 up use the thick gaskets as do most after market oil pan
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-30-2013, 11:03 PM   #3
cppursell
cppursell's Avatar
Okay, so the chrome pan is definitely aftermarket. I did notice that I can see an awful lot of the gasket in front. I didn't have an option to buy a "thick" gasket at the store, but should I just swap pans with an OEM one? I can re-use the gasket too.
Old 12-30-2013, 11:15 PM   #4
chiefcfd
chiefcfd's Avatar
I have always had leaks with the chrome timing covers and oil pans. They never seem to be the right fit. I would change both of them for original styles.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 12-30-2013, 11:18 PM   #5
cppursell
cppursell's Avatar
I found this thread, the 2nd post explains there's a different gasket for aftermarket oil pans. Should I get this gasket or a new old pan? http://forums.corvetteforum.com/c1-a...-at-front.html
Old 12-30-2013, 11:24 PM   #6
cppursell
cppursell's Avatar
I'm off to buy the thick 34510 gasket now! I'm confident that's the problem!
Old 12-30-2013, 11:54 PM   #7
Russ.W.
Russ.W.'s Avatar
Definitely the right choice and what I had to do with mine when changing pans.
The oil pan changed somewhere in the mid 70's I believe, and all aftermarket and repro pans are modeled after that later, wider ended pan.
The difference is slight ... probably be no more than 1/8" - but enough to cause dramas.
Here's the original on my '67 small block:
And here's the aftermarket:
Old 12-31-2013, 12:13 AM   #8
cppursell
cppursell's Avatar
This gasket is a lot thicker, I can't wait to bang my fingers and get oily again!
Old 12-31-2013, 12:06 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hope the new pan gets her al sealed up..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-31-2013, 12:43 PM   #10
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Ive always had great success using Permatex Aviation sealant brushed onto the gasket surface before installing gasket. It sticks like glue and never hardens. It is also oil and detergent resistant so it will stay in place and seals like a champ.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 12-31-2013, 03:46 PM   #11
trac209
The ultra thick gasket you have only fits a certain style of pan I tried to use one of those once and it was too thick to allow the pan to seal on the rails. Your vid is not working now so I can't see your pan.
trac209 is offline   Reply With Quote
Old 12-31-2013, 06:31 PM   #12
sprint_9
sprint_9's Avatar
It looks like the timing cover is bent or broke. If you look closely to the left side of the drip it looks like the entire gasket has a coat of oil on it that appears to me to be coming out from under the front cover. It is running down the gasket and dripping off of the corner of the gasket where it meets the pan lip.
sprint_9 is offline   Reply With Quote
Old 01-01-2014, 04:40 AM   #13
cppursell
cppursell's Avatar
Talking Re: Big Leak trouble, Help! Video of oil leak
Well I installed the 34510-T gasket and it stopped the leak!! This gasket is much thicker on the front. After driving it 25 miles on errands, under inspection it hasn't dripped! I noticed a small oil buildup so that could be a small seepage but nothing to worry about any longer. Woohoo! Happy new year!!
Old 01-01-2014, 08:19 AM   #14
mrolds88
Glad you got the leak stopped. One thing I noticed on the video was the harmonic balancer. It actually looks like the outer ring is loose. Would definitely check that thing over good.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-01-2014, 12:25 PM   #15
sprint_9
sprint_9's Avatar
Hmm must have been the video making the timing cover look suspect to me. In the picture you posted it looks great.
Old 01-02-2014, 11:27 AM   #16
alsriv2
alsriv2's Avatar
I never knew the difference in the pan shapes and the gasket requirements, guess I have been lucky enough that everything lined up and fit properly. Thanks for sharing your experiences with us and highlighting the fix.
Happy truckin'!
Alan
'69 Chevy C10 396BB
Old 01-02-2014, 01:06 PM   #17
cppursell
cppursell's Avatar
This was a big lesson to learn, thanks for all y'all'ses help . Go Old Iron!
307, leaking oil, oil, small block, step-side
