Old 01-02-2014, 04:39 PM   #1
Organism_ike
Oil Dipstick Tube Bolt Stripped
The 1/4" -20 hole in the block of my 305 that is used to bolt the dipstick tube to had the threads ripped out and won't hold a bolt anymore. As a result the dipstick tube is loosely sitting in its hole and isn't sealing well. I believe this is the source of the oil dripping down my starter (I'm sure this truck has quite a few more oil leaks then that though).
What would you guys do to hold the dipstick tube against the block now? I'd rather not have to go through the process of drilling the hole out for a bigger bolt or helicoil since it's hard to get to with the headers in the way.
1983 Chevy C10 LWB
305 SBC bored .030 with cast dished pistons
Summit RV Camshaft 204/214 .424/.444
416 Iron Heads
Performer Intake, Quadrajet, and Flowtech Long Tubes
TH350 2.73 10 Bolt
Organism_ike is offline   Reply With Quote
Old 01-02-2014, 06:03 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Oil Dipstick Tube Bolt Stripped
i had this happen on my k5. i took a piece of 18G sheet metal, wrapped it around the dipstik with a couple of bolts, then just bent the other end to another bolt hole.
i did put a big neoprene washer & some rtv around it to stop any leaks
dieseldawg142 is offline   Reply With Quote
Old 01-02-2014, 08:05 PM   #3
mrolds88
Use a 1/4 stud and some JB weld. Bolt it back in. Also look at an o ring at the bottom to
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-03-2014, 02:19 PM   #4
Organism_ike
I just use Ultra Black RTV and it always seals fine. The only reason the dipstick stopped sealing is because it moves around when I check the oil. I really hate doing anything with JB weld, especially on the block of my engine, but on the other hand I assume the hole is useless as it is now so JB weld won't hurt it any more than it is...
1983 Chevy C10 LWB
416 Iron Heads
TH350 2.73 10 Bolt
Old 01-03-2014, 03:24 PM   #5
77c10
77c10's Avatar
x2
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-04-2014, 08:43 PM   #6
Organism_ike
Copied Dieseldawg142 and made a little bracket by wrapping some left over sheet metal around the dipstick then drilling a hole so it could be bolted to the block in the hole next to the original one that got stripped. Same size threads as original too, 1/4" -20
I bet the hole i used is used on other chevy dipsticks from different models.
1983 Chevy C10 LWB
416 Iron Heads
TH350 2.73 10 Bolt
