Old 01-03-2014, 02:10 AM   #1
Paul83
Paul83's Avatar
Column Change
Will a 93 steering column from a chevy truck fit on an 85 chevy truck? Is there somwhere that might have this info.? Thanks for any help. It has the same switches it seems and both are auto. Just don't know if the wires are the same or the bolts would line up?
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that!
I like long walks on the beach, dinner by candle light, and poking dead things with a stick.
Paul83 is offline   Reply With Quote
Old 01-03-2014, 05:07 AM   #2
EddiesLow77
Cool Re: Column Change
It should fit i dont see why not i have a 77 chevy truck and i put a 77 impala steer column and a few wires were a lil diff but the bracket might need to be adjusted but its not that hard you can do it ......good luck....
EddiesLow77 is offline   Reply With Quote
Old 01-03-2014, 12:20 PM   #3
1774btcrew
1774btcrew's Avatar
Re: Column Change
It won't fit without modifications. The 1988 and up NON squarebody trucks had the part the seals to the floor welded to the column and they squarebody trucks did not. The length may be different as well. I haven't ever measured them side buy side but since I do rebuild steering columns I have had several of both styles. I guess what it comes down to is that anything can be made to work. It just depends on how much time and effort you want to put into it. I wouldn't do it since I feel there are a TON of squarebody tilt columns out there but that is just me.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-03-2014, 04:05 PM   #4
Paul83
Paul83's Avatar
Re: Column Change
I will just find one from another square. I have a buddy that said he would just give it to me is why I asked. Thanks for the replies.
