Old 01-04-2014, 04:09 PM   #1
Sodell
Sodell's Avatar
Measuring sway bar
I want to measure my swaybar, as it is still attached. It is either a 1" 1/16th or 1"1/8th. I measured the end on the truck at 1" 1/8th but not sure because it is hard to reach. Any one have a good idea for the measurement?
I would just remove it, but my local auto parts store has neither in stock so I will be ordering them online and want to make sure I get the correct size.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 01-04-2014, 04:16 PM   #2
Jake Wade
Jake Wade's Avatar
Re: Measuring sway bar
Do you have dial calipers? 1 1/16 and 1 1/8 end wrenches? You could even take a cresent wrench to close up on it and then measure with a tape.
Jake Wade is offline   Reply With Quote
Old 01-04-2014, 04:28 PM   #3
BMERDOC
BMERDOC's Avatar
I've always just used the open end wrench trick.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-04-2014, 07:10 PM   #4
Sodell
Sodell's Avatar
I should have thought of that...the ol mind does not help some times..Thanks
Scott
