01-07-2014, 12:03 PM | #1 |
Rusty Rockerfeller
Changing rear main and oil sender on 1500HD
Going to change the rear main this weekend. I bought the seal that included the plate and want to change the oil sending unit as well. One the trans is out, is it a pain to do? Thanks
01-07-2014, 03:51 PM | #2 |
Re: Changing rear main and oil sender on 1500HD
The oil pressure sender will be a lot easier to replace when the trans is removed.
01-09-2014, 08:36 PM | #3 |
laying low
You might as well go ahead and buy the oil pressure switch socket if you don't have one already. Only a thin wall socket will fit in there.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
