Old 01-10-2014, 09:41 AM   #1
of13swc
Widen wheel tubs question??
I need to widen my wheel tubs to fit my wheel/tire combo. Is there somewhere that makes a pre bent section that I can weld in to widen them. I do not have the capabilities or the knowledge to do it myself.
of13swc is offline   Reply With Quote
Old 01-10-2014, 10:06 AM   #2
jayoldschool
Moderator
Re: Widen wheel tubs question??
How about a set of used tubs to cut a section out of? If you want perfect, new tubs are only 80 bucks from Top Banana.
jayoldschool is offline   Reply With Quote
Old 01-10-2014, 10:06 AM   #3
PGSigns
PGSigns's Avatar
I bought a second set and split them adding 2 inches and just one seam to weld up. just offset the cut on the other tub the amount needed when you cut it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-10-2014, 12:46 PM   #4
DURG
DURG's Avatar
I used two sets of OEM ones also to make wider ones.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 01-12-2014, 09:12 PM   #5
of13swc
ok cool that sound like a plan?
Old 01-14-2014, 01:30 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
I used a second set of damaged OE wheel wells that I found to section...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-14-2014, 02:07 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Widen wheel tubs question??
My Ole' Stepside Mini Tubs $50.00:
"1962 Chevy C-10 Stepside Parts for Sale" & miscellaneous stuff
http://67-72chevytrucks.com/vboard/s...d.php?t=337099
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-14-2014, 06:24 PM   #8
kerber63
kerber63's Avatar
I bought a set of repop fenders, cut both old and new sets, welded them together for a few more inches. Keep in mind that you might need to add/move the skid strip mounting holes in the fender lips if you keep the wood bed. I added some and bent the lips to make it look stock where the strips go under.
kerber63 is offline   Reply With Quote
Old 01-14-2014, 07:39 PM   #9
RockTonka
RockTonka's Avatar
Just sectioned the stockers and added a 4" strip...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 01-14-2014, 07:56 PM   #10
familyfast64
familyfast64's Avatar
I didn't get to do mine but I thought it'd throw in a pic since there square n not round.
Live and let live
familyfast64 is offline   Reply With Quote
Old 01-14-2014, 08:19 PM   #11
chad64chevy
chad64chevy's Avatar
I widened mine 4 3/4", they are 16" wide, I also used 67-72 tubs had to cut the opening where they bolt to the inner bedside to match
chad64chevy is offline   Reply With Quote
Old 01-15-2014, 08:53 AM   #12
bigcowl-imp
bigcowl-imp's Avatar
So after you guys are putting fatter tubs in, What size rim and what off set with a fleet side bed ??? What tire ???
bigcowl-imp is offline   Reply With Quote
Old 01-15-2014, 02:26 PM   #13
datguy
If my truck sits lower, can the stock wheel tubs be made taller as well?
datguy is offline   Reply With Quote
Old 01-15-2014, 06:14 PM   #14
vin63
vin63's Avatar
That would be a challenge in not making it appear disproportionate since it would be quite narrow at the top without lengthening the wheel tub. If the top of your tire is above the hip line, it would be more practical to go with an aftermarket drag race type of wheel tub.
In my case, I raised the bed 1 inch in addition to widening the wheel tubs.
