Under construction!
Front:
Belltech Nitro-Active shock absorbers for a truck lowered 3"---SOLD! AC Delco DuraStop 1" brake rotors w/ only 5,000 miles of use---$60 shipped. Rear: DJM Deluxe 5" flip kit---$85 shipped. (Originally paid $175 + shipping.) ![]() DJM 2" adjustable hangers w/ upgraded hardware---SOLD!. ![]() New factory 52" 3+1 leafs springs---$185 shipped. (Originally paid $490.) All rear suspension components were installed on my truck but have 0-miles of use.
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 08-02-2003 at 11:09 PM. |
It followed me home?
Are those rear shocks, If they are I'll take'm
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#3 | |
Under construction!
Nope, just the front ones. ![]()
2001 Silverado bagged on 22's. *Sold* |
I'll take the shocks for the fronts, if cochino can't use them.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
Daniel,
Those leaf springs are for our trucks right? If they'll fit my truck, I might take em. Also, would you be willing to split up the shackle/hanger kit? I just need the shackles. Since I can come pick stuff up, I get a lower price right? ![]() |
#6 | |
Under construction!
Yes, I would be willing to split the hanger/shackle kit. I'll make you a deal but you have to drive the C10! ![]() ![]() *Edit* The leaf springs will fit 73-87' C10 trucks but make sure they'll fit your application (GM offered 52" and 56" springs).
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 07-19-2003 at 05:33 PM. |
#7 | |
Garage Queen Material
how much for the cnotch kit? when you get it?
![]() Join Date: Dec 2000
Interested in the flip kit if I can stay away from a c-notch.....
Thanks! doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
#10 | |
Under construction!
Well, if you want the parts sooner, I'll let you slide. ![]()
#11 | |
Under construction!
For now, the C-notch kit is reserved. If this other deal doesn't go through, I'll let you know. ![]()
#12 | |
Under construction!
The lowest you can/should go w/o a C-notch is 5". So, you'll be fine there. Let me know if we can make a deal. ![]()
#13 |
www.loweredd.com
are the shocks taken?
#14 | |
Under construction!
Yep. ![]()
#15 |
Under construction!
BTW, the leaf springs include all-new hardware!
#16 |
What years does the flip kit fit? I may be interested.
1978 Chevy C10 Currently under resto. 350 Getting face lift. .060, JEpistons, Modify heads. More will come with money. |
#17 |
I'm gonna have to pass on the axle flip, I've only got about 5" between my leaf pack & frame (not the bump stop mind you!!)
Thanks! Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 Last edited by doc70sub; 07-21-2003 at 09:56 PM. |
#18 |
Under construction!
The flip kit fits 73-87' C10 trucks.
#19 |
AND HOLDING ON TO THE C10
do you have the instructions on how to put the flip kit on,i have never done this but i always wanted my 84c10 sitting low and level.let me jknow if there is any welding involved before i take them i don't have a welder.but if there easy to put on i will take the flip kit if it hasn't been seperated.
66 swb/ss chevy c10 ![]() 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() 91 sdime 383/th350 ![]() Last edited by truckman32; 07-23-2003 at 05:29 AM. |
#20 |
Under construction!
#21 |
Under construction!
The prices of the rotors and leaf springs have been reduced.
#22 |
the check is going to be mailed tommorow for the ,deluxe flip kit ?will i need drop shocks for the rear flip kit and, will my truck ride rough
![]() i was hoping to go a little lower like 7rear.5 front i seen somebodys truck lowered 7/5 and the tire wasn't even tucked in
66 swb/ss chevy c10 ![]() 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() 91 sdime 383/th350 ![]() Last edited by truckman32; 07-24-2003 at 04:57 PM. |
#23 |
Under construction!
Yes, you will need lowered shock absorbers. The ride quality should be firm but not harsh. I think a 5/7" drop would look great! Spindles and coil springs will get the job done up front. Stick with quality components from DJM, Western Chassis, or Belltech.
#24 |
you still have the shackles?
1984 C10 SWB Custom Frame Blow Through Carb Single Turbo Hope to be on the road by Summer 2018 1967 C10 CST LWB 327/PG Original Running Driving Future Project |
#25 | |
Under construction!
Yep. ![]() Did you receive the spindles yet? ![]()
