Old 01-16-2014, 08:16 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Rear shackle question
I am installing a 2-1/2" Skyjacker lift with new leaf springs (front & rear) in my 70 K10. I had to cut into my stock rear shackles in order to get the rear leafs out. Ended up destroying them. What should I use for replacements, and where can I get them. I'm not doing a shackle flip, just installing new Skyjacker springs.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-16-2014, 08:57 PM   #2
jeffro308
Re: Rear shackle question
LMCtrucks.com has them. part number 34-0036, page=153 of the online catalog. At 15 a piece you can't go wrong.
jeffro308 is offline   Reply With Quote
Old 01-16-2014, 09:31 PM   #3
derotoreut
derotoreut's Avatar
I see that. Any idea how these compare to stock OEM shackles?
~ Dan
Old 01-16-2014, 09:45 PM   #4
ryanroo
ryanroo's Avatar
I don't know if the part is still available, but i got a set from GM many moons ago. they are still sitting unused on the frame of my truck. if you would like, i can go see if they have a PN stamped on them.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-16-2014, 11:47 PM   #5
jeffro308
I really can't say compared to stock. I've not been dis-pleased with LMC to date. If you're not using them for a shackle flip you'll be OK. My opinion.
Old 01-17-2014, 01:42 AM   #6
swamp rat
swamp rat's Avatar
I replaced mine with shackles from ORD and i added greasable bolts as well, real nice quality stuff. scroll down to post #78
http://67-72chevytrucks.com/vboard/s...=595019&page=4
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-17-2014, 01:49 PM   #7
derotoreut
derotoreut's Avatar
PN and picts would be great. Thanks. If they're unused are you willing to part with them?
~ Dan
Old 01-17-2014, 03:42 PM   #8
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Last time I bought a set from LMC they were regular GM issue shackles made by Dayton and even come with a new bushing installed.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-17-2014, 08:35 PM   #9
ryanroo
ryanroo's Avatar
this is the Number stamped on the ones i purchased from a GM dealer, about 12 years ago. might be closer to 15. wow. now i feel old...
72 K20 12v build
Old 01-17-2014, 11:40 PM   #10
derotoreut
derotoreut's Avatar
Thanks Ryanroo.
~ Dan
Old 01-18-2014, 11:34 AM   #11
ryanroo
ryanroo's Avatar
No problem. i needed an excuse to take them off the frame! after the conversion to airbags, they were just sitting there in the hangers.
72 K20 12v build
