Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-19-2014, 01:57 PM   #1
ljackson
ljackson's Avatar
WTB 60-66 suburban or panel filler neck
60-66 suburban or panel filler neck, door and sheet metal. I want to install a door and fill assembly in my 64 fleet. I have the fuel tank already under the bed.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 01-19-2014, 02:19 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: WTB 60-66 suburban or panel filler neck
I have a door off of a 59 nomad, it might work if you can't find anything else.
LT1 Burb is offline   Reply With Quote
Old 01-19-2014, 02:26 PM   #3
ljackson
ljackson's Avatar
Thanks. I'll keep it in mind. Is it just the door? Do you have a pic? After a quick web search, it looks to have a lot of curve. Quite a bit more than fleetside bed?
Old 01-20-2014, 01:20 AM   #4
Captainfab
60-66 Nut
I have some Suburban/Panel fuel fill doors with the surrounding sheetmetal. I'll have to check and see if I have any fill tubes left.
Old 01-20-2014, 07:39 AM   #5
ljackson
ljackson's Avatar
Thanks, Capt
Old 01-24-2014, 08:22 PM   #6
ljackson
ljackson's Avatar
Any luck Capt.?
Old 01-25-2014, 12:29 PM   #7
Captainfab
60-66 Nut
Sorry but I haven't had much time with working 12hrs a day 7 days a week. I did not find a filler tube at my shop, but I should have one at home in the garage. I just need to find the time to look for it. I'll try and get to it this weekend.
Originally Posted by ljackson View Post
Any luck Capt.?
Old 01-26-2014, 10:11 AM   #8
ljackson
ljackson's Avatar
Thanks Capt. I apologize. I didn't mean to rush you. I'm getting ready to do it in March when the weather warms.
Old 01-27-2014, 01:03 AM   #9
Captainfab
60-66 Nut
No need to apologize. I did find some filler tubes. I'll send you a PM.
Old 02-09-2014, 01:19 AM   #10
Captainfab
60-66 Nut
Here are a few pics of what I have. It does have a small rust hole on the backside as shown in the one pic.
Old 02-09-2014, 11:36 AM   #11
ljackson
ljackson's Avatar
Thanks Capt for fixin me up, it looks good to me. It appears to be easily repairable. Just to be sure I understand how these fit, the "box" will go between the inner and outer bed sides (skins) and the filler will connect to my tank on the plane between the top of the frame and the bottom of the bed wood? When it is set up like described, the curves will match?
Capt. Said "It looks like the shipping will be $21.00 which makes the total $86.00". actual shipping was $32.75
Capt, I want it. PM sent
Old 02-09-2014, 12:15 PM   #12
LT1 Burb
LT1 Burb's Avatar
I did look at the wagon one and it is way to curved for a pickup.
Old 02-09-2014, 12:31 PM   #13
ljackson
ljackson's Avatar
Thanks for the input.
Old 02-09-2014, 02:07 PM   #14
Captainfab
60-66 Nut
I haven't installed one of these in a pickup box yet, but yes the filler tube should pass between the top of the frame and the bed floor. If you are using the Blazer tank, you may have to modify the filler tube , the tank neck or both. It shouldn't be difficult to do.
The inner box of the filler door assembly will interfere with the inner bed panel. You will need to either trim the fill door box, or make a small bulge in your inner bed panel. The Suburbans and Panels have a bulge in the inner wall to accomodate the filler box.
I replied to your PM.
Old 02-09-2014, 04:43 PM   #15
ljackson
ljackson's Avatar
The inner box of the filler door assembly will interfere with the inner bed panel. You will need to either trim the fill door box, or make a small bulge in your inner bed panel. The Suburban’s and Panels have a bulge in the inner wall to accommodate the filler box.
Thanks for the info, I built my tank to between the frame rails.
If anyone that is following this wants to see what I built: http://67-72chevytrucks.com/vboard/s...d.php?t=428182 Post # 4.
Thanks, I have not been able to actually look a sub or panel. I’ve been trying to see from forum photos.
I believe this is going to work well.
PM sent regarding Payment
Old 02-22-2014, 07:03 PM   #16
ljackson
ljackson's Avatar
The filler arrived in great shape. Thanks to Captainfab. Balance for shipping sent to capt's PP acct.
Old 02-23-2014, 12:13 PM   #17
ABNGRNT13
ABNGRNT13's Avatar
Location: Fort Mitchell, AL (out the back gate of Ft Benning)
By chance, do you have another one of these door setups?
SSG Walker Harris
'72 Cheyenne Longbed
'66 Panel
'66 Short Stepside
'65 Short Fleetside
ABNGRNT13 is offline   Reply With Quote
60-66, filler neck, fuel door, panel, suburban
