Old 01-19-2014, 03:09 PM   #1
tgfeller
Spindle bearing surface marred
When I removed my spindle needle bearings I resorted to a die grinder. Hastily I cut and marred the inside spindle surface a bit. It is in one section and a deep enough divot to feel. My new bearing pressed in tight, Is that anything I should worry about?
tgfeller is offline   Reply With Quote
Old 01-19-2014, 04:25 PM   #2
swamp rat
swamp rat's Avatar
Re: Spindle bearing surface marred
Your talking the needle bearing cage on the inside of the spindle hub correct.
I don't think it would be a problem its just a support for the axle, not really load bearing.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-19-2014, 04:34 PM   #3
ryanroo
ryanroo's Avatar
agreed. if it is just the stub shaft support needle bearings, you'll be fine. i assume its not drastically deep so as to affect the integrity of the spindle much.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-19-2014, 05:25 PM   #4
tgfeller
Correct, just on the inside spindle itself, nothing to effect integrity and still a very tight fit. Thanks that puts me at ease!
