Old 01-19-2014, 08:18 PM   #1
Kaysen
1986 black swb build thread
After having a black 1987 chevy swb from '06-'10 and selling it to fund my now exs crew cab, I've finally got another one to replace it! (The truck, not the wife)
I've been looking for a black 85 or 86 swb chevy for a while to have as my Saturday night cruiser and piddle project. It had to be black on black, have every option possible with the exception of a hood ornament/bed rails/bumperettes, and completely rust free. So after months of looking everyday, and selling my 86 K5, I found one 11 hours away in Thayer, Missouri. I bought it Christmas Eve 2013 (Merry Christmas to me!!)
So on with the truck. Its a loaded 86 silverado, PS/PB/Cruise/AC/PW/PL/Cargo lamp/clock/dual tanks/etc. Pretty clean overall and not a spec of rust that Ive found anywhere.
350/350/3.73 posi 10 bolt.
Ive got a bunch of plans for it and I will post them as I progress. Basically just tidy everything up and make as solid of a driver as possible. Starting with ditching the janky edelbrock carb and rebuilding a q-jet for it, pulling and cleaning the intake and valve covers, replacing thermostat, valve seals and running compression and leakage tests on all cylinders. This spring I will convert the AC and might go ahead and do a 700r4 swap.
Kaysen is offline   Reply With Quote
Old 01-19-2014, 08:37 PM   #2
Kaysen
Re: 1986 black swb build thread
Passenger side
Old 01-19-2014, 08:40 PM   #3
Kaysen
Another passenger shot
Old 01-19-2014, 08:41 PM   #4
rusty76
rusty76's Avatar
Clean truck
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-19-2014, 08:41 PM   #5
Kaysen
Hood
Old 01-19-2014, 08:44 PM   #6
Kaysen
Thanks rusty, I wanted to start this build with the best one I could find.
Old 01-19-2014, 08:45 PM   #7
Kaysen
Last one of the inside. Still dirty. All I need is some time
Old 01-19-2014, 08:48 PM   #8
Kaysen
Last one for the day, my 86 and my brother Nico's 84. We both took advantage of the pretty day and cleaned them up.
Old 01-22-2014, 02:06 PM   #9
Kaysen
First thing to address is the lack of cup holders. I had a similar setup on my 87 and it worked well so I'm gonna do the same again. I use an 06 style silverado cup holder with the factory brackets. Then just weld a clamp to the bracket to attach it to the seat frame. Here's a rough sketch I did as well as the clamps I'll use.
Old 01-22-2014, 02:07 PM   #10
Kaysen
Clamps. Hopefully I can do this today
Old 01-22-2014, 02:11 PM   #11
Low Elco
That... is one clean truck! I'll have to watch the cupholder mod. Where did the j-hooks come from?
Low Elco is offline   Reply With Quote
Old 01-22-2014, 02:38 PM   #12
77c10
77c10's Avatar
Clean ride.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-22-2014, 02:40 PM   #13
JWall
Frequent Flyer
JWall's Avatar
Good lookin' truck!
- Justin
1 Owner 1976 SWB
Old 01-22-2014, 02:42 PM   #14
Kaysen
Thanks man, I appreciate it! The J-clamps/hooks were on some old unused conveyors at work. Im not really sure what they were for originally but I think they will work perfectly for my application!
Old 01-22-2014, 07:40 PM   #15
MR COUNTS
Those clamps look like 1/4 20 beam clamps that you can purchase from an electrical supply house.
MR COUNTS is offline   Reply With Quote
Old 01-23-2014, 07:58 AM   #16
DBLSPRT68
DBLSPRT68's Avatar
BOTH of those trucks are very nice!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 01-23-2014, 11:17 AM   #17
Low Elco
I was thinking the exact same thing. Super clean trucks. Jealous!
Old 01-25-2014, 02:02 AM   #18
Gordonr1973
Home Built '87
Gordonr1973's Avatar
X2!!
Great start!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-29-2014, 01:15 AM   #19
Kaysen
Finally found some time to work on the truck. I got a 1 1/4 sway bar off of a one ton cleaned, painted, and installed with new poly bushings. Had to pull the sway bar mount brackets off my parts truck but everything went on really nice.
Old 03-29-2014, 01:18 AM   #20
Kaysen
Also pulled the seat and carpet out. Took the carpet to the car wash and got all the gunk off of it. It looks much much better now
Old 03-29-2014, 01:24 AM   #21
Kaysen
While the seat was out I installed the cupholder. I wasn't able to use the brackets like I'd planned on doing without some modification to the bracket, so I drilled holes in the seat frame and put some screws in it. I'm really happy with it, it's nice to have good cupholders.
Old 03-29-2014, 01:25 AM   #22
Kaysen
Here's one of the bottom showing how it's attached, in case anyone wants to copy it.
Old 03-29-2014, 01:31 AM   #23
ChevDog1
ChevDog1's Avatar
Nice truck! If mine was that clean, I'm not sure I could call it a project!
ChevDog1 is offline   Reply With Quote
Old 03-29-2014, 04:55 PM   #24
Kaysen
Thanks man, I appreciate it but it's definitely a project. Not that it really needs anything but more just to have one to tinker with and make as nice of a driver as possible.
Here's a shot of the sway bar all bolted on. It handles much better now as opposed to not having one at all like before.
Old 03-29-2014, 04:59 PM   #25
Kaysen
I also got to clean it up today on top of getting to take care of a bunch of projects around the house. Plus got to meet a fellow board member and visit a while about squares and engines, all in all a pretty dang good day!
