Old 01-21-2014, 02:17 PM   #1
hitorque250
Aftermarket Header installation problems
Hi
I am in the midst of restoring my grandfathers pick up. I left the six (250) in for the sake of memories. I wanted a little more out of it so in addition to an overhaul, bigger cam, offy intake, and Holley 390, I installed a set of headers. The problem is that the original fasteners don't fit with the aftermarket headers and intake. I used large washers and bolts instead and still the headers pull free and have made a nasty spot on my new paint job. How do some of ya'll have your headers and intakes fastened?
Thanks a bunch!
Will Hill
hitorque250 is offline   Reply With Quote
Old 01-21-2014, 10:22 PM   #2
spatz
Re: Aftermarket Header installation problems
Welcome to the site. you will need to get header bolts preferably with the lock ring to hold in place. Standard bolts will vibrate lose.
spatz is offline   Reply With Quote
Old 01-21-2014, 10:29 PM   #3
The headers should have come with proper bolts/hardware. BTW,there are no factory headers. All headers are aftermarket
Old 01-22-2014, 11:32 AM   #4
hitorque250
Thank you both, I will run down to NAPA and see if I can get a set and give it a try. Thanks
Will Hill
250, 4bbl, exhaust, headers, offy
