Old 01-26-2014, 11:05 PM   #1
Metalaroundstone
Question about bent control arm on 66
I could use a little advise. While changing the upper ball joint on the passenger side of my truck, I noticed that the front lip of my lower control arm was bent back slightly. If you look at the picture, I have pointed out a gap between the front hole in the control arm and the shaft nut. This strikes me as bad news and that I need a replacement control arm. Is this as bad as I think? Can the control arm be bent back, or is this now scrap metal?
I also noticed that my upper ball joint shaft was bent about 20 degrees. But I think this was the result of a different impact from the one that been my lower control arm. Fortuneately, I don't see any issues with the upper control arm.
Thanks for any advice about this.
Metalaroundstone is offline   Reply With Quote
control arm, suspension
