01-27-2014, 08:12 PM | #1 |
Relocated fuel tank question
I have a 1971 C-10 with the traditional fuel tank mounted just behind the front seat. I would like to remove the stock tank and replace it with some type of under-bed fuel tank.
Unfortunately I can not use the most common type of aftermarket fuel tank that mounts at the rear of the bed in-between the frame rails as: 1. I already have an aftermarket trailer hitch that hides in that area. 2. In the summers I install a vintage Alaskan pop-up camper in the bed which would make it nearly impossible to fill up the fuel tank (as the gas cap is usually on top of the bed or mounted in an area of the bed side). +++++ My dad bought new a 1971 Cheyenne that had an optional fuel tank located on the underside of the front left portion of the bed (just rearward of the driver). I don't remember if the tank was installed from the factory or installed by the dealer … but it definitely wasn't installed after leaving the dealership. Questions: 1. Does anyone know if this tank was factory or dealer installed? 2. What was the size (in gallons) of the auxiliary fuel tank? 3. Does anyone reproduce the tank, mounting straps, and fuel filler hose assembly? 4. Does anyone reproduce a similar tank that is larger capacity than the original side tank? |
01-27-2014, 09:22 PM | #2 |
Re: Relocated fuel tank question
You could just put in a saddle tank and mount the filler tube in the fender well. This is how the factory mounted them. The ones you see with the doors in the bed sides are add on tanks installed by dealerships. I think the saddles also carry more fuel than the cab tank.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
01-27-2014, 09:30 PM | #3 |
There was one of those very tanks on here last week for sale I think. Jim
01-27-2014, 10:04 PM | #4 |
here is the thread http://67-72chevytrucks.com/vboard/s...d.php?t=612928
there is a craigs list ad for one for sale good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
01-27-2014, 11:08 PM | #5 |
While you could install a saddle tank or even a pair (~19 gal each) they were not intended to replace the factory tank and most but the RPO NL2 tank or GM acccessory tanks do not feature senders for the fuel gauge. Not to mention saddle tanks were not EEC compliant as was required on 1/2 ton trucks.
Camper, even a 8' Alaskan weighs about 1700lb wetIIRC. Might want to consider how much your truck actually weighs. Suggest weighing the front and rear axles all loaded uo to see where you are at. An overloaded semi-floating axle is not a good thing. As a final note moving the tank rearward from the cab will increase rear axle weight where you migh not have much if any margin. The General Information section of the factory service manual has good loading information as does the drivers handbook (owners manual).
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-28-2014, 01:09 AM | #6 |
the boat guy
I have an underbed tank (fuelcellguy) and a trailer hitch on my swb.
Fuel door on the outside of the bed sourced from a 90s chevy truck.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-28-2014, 12:55 PM | #7 | |
There are numerous references to that saddle tank being a 1972 only option … however, my dad's 1971 Cheyenne has the exact same saddle tank, filler neck, in-cab tank choosing valve (mounted on the floor), and a switch that would allow viewing the fuel levels in the two different tanks. Thus, it can't be a 1972-only option. (Note: my dad bought the truck new and has owned it ever since. Thus, it's not like someone else installed it.) In other news, does any company offer a reproduction of this factory saddle tank setup? |
01-28-2014, 02:06 PM | #8 |
On the NL2 I agree that it was offered earlier. The Custom Camper brochure lists it and 71 painted trucks. Strongly suspect it was a mid 71 release. Still trying to nail that down. Do you have the VIN or production date of your dad's truck?
As far as aftermaket goes I haven't seen any but a member did have and aluminum tank welded up a couple of years ago.
01-28-2014, 08:29 PM | #9 | |
My dad (who still owns the truck to this day) just looked at the VIN tag and he said that in addition to the VIN info (see below) that the tag also said 6/71, indicating that it was built in June of 1971 … which is very late in the run. Here is the first part of the VIN info (but missing the last two numbers of the VIN for privacy). CE241S6730 If I am deciphering correctly, the VIN equates to: C = 2WD E = V-8 engine 2 = 3/4 ton 4 = pick-up 1 = 1971 S = St. Louis built |
01-28-2014, 09:07 PM | #10 |
Wow, last of the last 71s! Thanks for sharing.
Does he have a build sheet by chance? Now of course we need a picture of that truck and your dad together!
01-29-2014, 09:32 PM | #11 |
the boat guy
Swamp rat wanted to see pics of my underbed tank and hidden hitch.
From behind. Cell is hidden by the not so hidden hitch brackets. Passenger side. Cell flange to the outside, hitch flange to the inside. Rear of tank. From L to R license plate bracket, hitch, fuel cell. Filler from 90s chevy truck.
01-30-2014, 03:23 AM | #12 | |
Thanks for posting this, so it looks like the tank flange is sandwiched between the frame rail and hitch brackets correct?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-30-2014, 02:37 PM | #13 | |
the boat guy
Is it secure and reliable? Haven't lost a trailer yet.
