'72 4x4 Dana 44 spindles... anywhere?
Hey all. In need of a set of Dana 44 spindles for my '72 K10. Having a hell of a time finding these... no one has new ones that I've found, even the specialty guys. Can find lots of '73 and up spindles, but not the older ones. Anyone know a source for this kind of thing? Or does anyone know of a work-around using a different D44 spindle and bearing combo, without replacing the rotors? Thanks!
![]() Join Date: May 2003
Re: '72 4x4 Dana 44 spindles... anywhere?
You can use the 73 and up, ( Even from corp 10 bolts ) but you have to use the hub and spindle as a unit because the bearings are different sizes.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Thanks! Do you know if the '72 rotors will work on a '73 hub?
That I can't answer. When I did mine I swapped rotors also !
No worries, thanks anyway! Anyone else have any suggestions?
Man, i scrap yarded a 72 d44 a few months ago. would have been great for this...
i would bet a dollar the rotors are the same. |
What!? And you the only other Durango guy I know on here?! That would've been too easy... shucks.
