Old 02-08-2014, 01:55 AM   #1
69 blue coupe
Should I bag it?
72c10 swb should I bag it or lower it? What the advantages vs the disadvantages
69 blue coupe is offline   Reply With Quote
Old 02-08-2014, 05:14 AM   #2
andrewmp6
Re: Should I bag it?
Bags will ride smoother and give you adjustable ride height,The con to bags is the price vs static lowering would be.
andrewmp6 is offline   Reply With Quote
Old 02-08-2014, 11:03 AM   #3
slowcpe
slowcpe's Avatar
If bagging is in your budget, go for it. I battled with the same decision and decided on bags.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 02-08-2014, 11:08 AM   #4
andrewmp6
If you have the truck arms in the rear http://www.azproperformance.com/Pro1...r-Bag-Kit.html
Old 02-08-2014, 01:21 PM   #5
Pro Performance
Pro Performance's Avatar
Thanks for posting the link andrewmp6. Our Pro1 kit linked above is a great kit and a lot of forum members are running this. I too, lean towards bags for the adjustability aspect.
We actually have a sale going on this month for the Pro Series kits. Our Pro1 already has built-in discounts into the price, but we took another $115 off this month.
Feel free to give us a call anytime, and would be glad to help you choose a suspension setup that works best for you and your budget.
http://67-72chevytrucks.com/vboard/s...d.php?t=614788
Travis
Pro Performance is offline   Reply With Quote
Old 02-11-2014, 04:44 PM   #6
baclay9
My biggest suggestion is if you are going to bag it at least get a rudamentary air management setup. Compressor, tank, switches. Messing with shrader valves is a PITA for anything but mock up IMHO.
I know you didn't mention schraders but I saw this as a money saving avenue when I bagged my front end but it just wasn't worth the hassle.
baclay9 is offline   Reply With Quote
Old 02-11-2014, 04:50 PM   #7
STPrider
STPrider's Avatar
In response to baclay9, i definitely see where you're coming from. However, it really depends on how you want to use your air suspension. Air bags offer a great ride, and I really enjoyed my truck while I had it on schraeder valves for a summer. Just make sure they don't leak, that could be a real hassle.
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 02-20-2014, 12:46 AM   #8
badmex67c10
Should I Bag my 67 swb or go with early classic 4/6 drop kit?
badmex67c10 is offline   Reply With Quote
Old 02-20-2014, 03:07 AM   #9
andrewmp6
Depends your budget and can you do the work yourself?
Old 02-20-2014, 09:20 AM   #10
STPrider
STPrider's Avatar
How do you want to use your truck?
Old 02-21-2014, 01:25 AM   #11
badmex67c10
Well I just drive her or on weekends. Right now she is lowered with Bell tech Springs on the back work Nitro shocks. The front just regular cut Springs. The stance looks like a 3/5. Areas that I may drive are rough and bottoming out. So you could imagine the ride. On the Hwy it's smooth. I do not want to cut the bed.
Old 02-21-2014, 08:40 AM   #12
72MARIO
72MARIO's Avatar
I regret bagging our 68 Suburban because I didn't spend the money on a air ride management with height sensors. Very difficult to get the front set back to alignment specs.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-21-2014, 09:23 AM   #13
STPrider
STPrider's Avatar
Well it probably will be over $500 to get your truck set up with shrader valves, and even then, unless you get a perfect, leak-free system, you will probably have to spend 5-10 minutes every weekend before you drive, getting the bags to aligned height. The ride quality is great, and when I daily drove my truck on shrader valves, I only had to adjust them about once per month. It's personal preference.
You might get good results with proper drop springs in the front, too!
