Old member
Here are the 1 3/4" long tube headers www.hawksthridgencamaro.com installed on my LSx 6.0 in the 71. They fit well with very little frame work. In fact I bet most can't even tell where they did the work on the frame.
![]() ![]() http://www.hawksthirdgenparts.com/pr...Collector.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Hawks Headers
$700 is budget? Holy crap. My schoenfield swap headers were like $300 and required no frame trimming. Not to knock em but budget is mis used I think haha
#4 | |
Old member
![]() Quote:
![]() Join Date: Oct 2013
Re: Hawks Headers
Are you running Schoenfeld headers on a 67-72? I scored on a used set, and am hoping they'll clear the UCAs with the engine slid all the way back
Re: Hawks Headers
Yes sir, my only issue was the factory linkage in the way and the factory trans crossmember, I trimmed 2" off the pass collector and chopped a U bend in half and spun one side 180* to make an S bend kinda. If it was my truck I would of built a new crossmember but at the time it was my brothers and he was on a budget.
#7 | |
Re: Hawks Headers
Re: Hawks Headers
Ya shift linkage, I was using a th350 so it might be a tighter fit for you a little bit. I had tons of a arm clearance but I built my own solid mounts.
Re: Hawks Headers
I did see lokar had a cable shift to take the place of the arm. I was going to look into it as I had trouble shifting all the way to "first"
I swapped to a manual so I never looked further into it. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
