Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 02-12-2014, 05:48 PM   #1
Howard Elliott
polishing valve covers
Looking for some help as to the best and least expensive way for me to polish my aluminum valve covers and if that goes good maybe the intake too. Any help would be appreciated
Howard Elliott is offline   Reply With Quote
Old 02-12-2014, 06:14 PM   #2
slikside
slikside's Avatar
Re: polishing valve covers
Howard,
This is the parts board. Items for sale. Your question should go in the general forum.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 02-12-2014, 09:52 PM   #3
novafrog
novafrog's Avatar
Question Re: polishing valve covers
Originally Posted by slikside View Post
howard,
this is the parts board. Items for sale. Your question should go in the general forum.
well !!!
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears
70 nova 5.3,350 trans
80 z28 350,350,trans,bought new
03 cat.
06 gmc swb ext cab
novafrog is offline   Reply With Quote
Old 02-12-2014, 09:56 PM   #4
novafrog
novafrog's Avatar
Originally Posted by howard elliott View Post
looking for some help as to the best and least expensive way for me to polish my aluminum valve covers and if that goes good maybe the intake too. Any help would be appreciated
mothers mag polish,lots of work but will do the job,intake i dont no
03 cat.
06 gmc swb ext cab
Old 02-13-2014, 12:04 PM   #5
Howard Elliott
NOVAFROG; Thanks for the comeback. I didn't know about the detail forum until this post. After all the different kinds of posts on the parts forum, as Hillary would say, what difference does it make. Besides, how many members check the detail forum often?
I'll try the mag polish. Thanks again
Howard
Old 02-15-2014, 12:30 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Take some time and search the web for razor buffs. These are small round buffing wheels (3" to 4" in size) that can be used on either an air die grinder or an electric one. With the different polishing material and these buffs, you can polish your valve covers out without working your elbow grease out of the socket. I get my polishing sticks at local truck stops and then use the buffs to do the work.
Oh and by the way Howard, this is the detailing section. Just an observation
Frank
piecesparts is offline   Reply With Quote
Old 02-15-2014, 02:12 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Are your covers and intake "polished" (smooth finish) already, or are they raw (as cast) aluminum?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-16-2014, 01:00 PM   #8
Howard Elliott
Thanks Frank and Leddzepp
The Valve covers are already smooth but the intake is not. I'll bead blast the intake and, with your information, polish the valve covers.
Thanks for the help guys
Howard
Old 02-20-2014, 06:20 PM   #9
71K20chevy
71K20chevy's Avatar
You might consider clearing the intake once it's blasted, that way you won't have to polish it.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-20-2014, 06:30 PM   #10
piecesparts
Careful on your choice of clear coat. I have seen many that turn yellow with the application of some engine heat.
Frank
Old 02-20-2014, 08:01 PM   #11
TheBlueBomber
TheBlueBomber's Avatar
I'm in the process of doing mine right now... Jon (1963c-10) put 40hrs polishing one of his and it came out quite well
I started sanding with 180 and am at 400 now (granted mine had blemishes) going to work my way up to 1000 and finish with 1200 grit then polish
Heres how he did his http://67-72chevytrucks.com/vboard/s...519869&page=16
and how it came out http://67-72chevytrucks.com/vboard/s...519869&page=17
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 02-20-2014, 08:06 PM   #12
TheBlueBomber
Those pictures dont do any justice. I have seen the cover he did in person and its spectacular.
I've taken a break on mine since I'm going LS and can't use those covers on the new motor.
Austin
