02-19-2014, 10:23 PM | #1 |
Roto Reuter thats the name...
Can someone ID this rear axle spring plate?
It looks like the PO did a U-bolt flip on my '70 K10. I'm in the process of installing a Skyjacker 2-1/2" leaf spring kit (front & rear). I like the idea that the rear U-bolts are mounted from bottom up. Just want to be sure that this axle spring plate is strong enough. Not doing any off-roading. Some of them seem wimpy. This one actually seems pretty beefy. Wondered what the plates might have come off of? Any ideas?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-19-2014, 11:28 PM | #2 |
Re: Can someone ID this rear axle spring plate?
Looks aftermarket to me.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
02-19-2014, 11:37 PM | #3 |
Serious? I didn't think it was, but maybe. Look at the one from this ORD U-bolt flip kit (pic on upper right). Looks the same as mine and appears to be stock.
http://www.offroaddesign.com/catalog/uboltreversal.htm Their aftermarket design plates are shown in pic near bottom.
02-19-2014, 11:43 PM | #4 |
Windy Corner of a Dirty Street
Looks bone stock to me. Same ones I have that I know are factory GM
Mine looks funny because I relocated the center pin after a shackle flip.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
02-19-2014, 11:59 PM | #5 |
Looks normal to me as well.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
02-20-2014, 01:06 AM | #6 |
Below is a better view of the factory spring plates. These are on my ’89 Burb. Both of my trucks have 10.5” 14 bolt rear axles but the spring plates for ½ ton axles look the same, the u-bolt holes are just closer together.
I don’t recall 67-72 4x4 trucks using the spring plates under the axle like mentioned on the ORD page but I could be wrong. Usually it is only 1 tons that have the spring plates below the axle while ½ and ¾ tons had a spring plate on top of the springs with the u-bolt threads pointed up. On the other hand, my ’68 GMC ½ ton 2wd with a factory Dana 60 semi-floating rear axle does have the spring plates below the axle like a 1 ton. Dana rear axles in 67-72’s could have been the exception. Someone like Special-K would probably know for sure where the spring plates were on a stock ’70 K10 but I can tell you the spring plates on the truck in question are indeed factory spring plates. You can see the right rear one on the far side better
02-20-2014, 02:47 PM | #7 |
The Eaton's have the downward facing U bolts , i think the 14 bolts had the opposite.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-20-2014, 05:30 PM | #8 |
Looks like it came off a late 70's 4x4. If I recall they were just like that on my 78' Blazer
02-20-2014, 06:49 PM | #9 |
Good to know it's a stock spring plate. Looks exactly like DirtyLarry's. Even has the nubs on the sides. I just wanted to get an idea what it might have been off of. Since it's OE and pretty strong I should be in good shape. From what I understand, up to '72 used square U-bolts mounted from top down. After that ('73 and up) they used round U-bolts mounted from bottom up. That's just what I've been told… Could be wrong though.
02-21-2014, 01:07 AM | #10 |
My '72 GMC K1500 had a 12 bolt rear, with square u-bolts that faced downward. And my '70 C20 came with a Dana 60 with square u-bolts facing downward. I guess I shouldn't have assumed that derotoreut's spring plates were aftermarket, but as far as I know they aren't OE for a '70.
02-21-2014, 08:07 AM | #11 | |
02-21-2014, 04:10 PM | #12 |
I agree, it looks better IMO. And I've seen so many spring plates rusted when on the bottom.
02-21-2014, 04:18 PM | #13 |
I have those on my truck, I believe they started using those in 73.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
02-21-2014, 07:40 PM | #14 |
Currently Blazerless
All 67 to 72 4x4s 1/2 and 3/4 ton came from the factory with the bottom saddle, the round u-bolts facing up with the top plate started in 73. I have always converted to the round u-bolts with top plate on my trucks. Like already mentioned the saddle was prone to holding in muck and causing rust. Ive even had to weld up a few axle tubes that had corroded thin where the u-bolts were in contact with the tube.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
02-21-2014, 10:36 PM | #15 | |
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
02-25-2014, 10:32 AM | #16 |
Looks like spring plate from 73-87(88-91) square body 1/2 3/4 ton
A 1 ton frame always had square u-bolts facing down for frame to helper spring clearence at anchor plate and easiest way to tell a 1 ton wider frame rails are the shocks are mouted on the inside of frame i am refering to the 73-87(88-91).
100:1 low gear! |
04-15-2019, 11:05 PM | #17 |
I know this is an old thread but maybe someone will chime in. Does anyone know if there is a piece of rubber under the u-shaped part in the plate? I could have sworn when I took apart my sprigs there was a rubber piece filling the void with a hole on the bottom side to locate the plate on the spring center bolt. I have taken apart others that didn’t have the rubber and can’t seem to find replacements anywhere. Are they non existent or not needed? Do you just center the top plate over the center bolt by eye?
Posted via Mobile Device |
04-17-2019, 01:14 AM | #18 |
Never seen rubber of any kind between all the axles I have taken out
04-24-2019, 07:40 PM | #19 |
04-24-2019, 07:41 PM | #20 | |
