Old 02-24-2014, 11:38 AM   #1
sambudo
sambudo's Avatar
Froze up bolt on i-250
In the process of power steering conversion, was getting ready to attach the p/s bracket. The two bolts that are in the front, I can't seem to budge them. The bottom one felt like it was going to snap off. So now I'm applying Kano Kroil penitrating oil to the bolts. Is their a better product out there, that I should be using? I also have CRC Freeze off.
What are some options to take this bolt out? Heat it up? I've nevere done this, how do i heat it up with a butane torch? And whats the process for this? Thank you all for your help.Name:  00F0F_iWt4CAqMucK_600x450.jpeg
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 02-24-2014, 01:48 PM   #2
airdale94
airdale94's Avatar
Re: Froze up bolt on i-250
Heat. Butane probably won't do it. Propane might. You really need a oxy/acetalyne torch. On bolts it's best if you can heat where it screws in to. You can heat to a bright (orange!) (steel) without ruining your heat treating. If you can't get to the threads and don't have a torch just heat the bolt up as much as you can and twist away.
You can try heat, and penetrating oil, and rapping the bolt head with a hammer. Spray the penetrating oil on it while it's hot. It may catch fire but it won't be extreme, you can blow it out with your breath.
Good looking engine!
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 02-27-2014, 04:38 PM   #3
sambudo
sambudo's Avatar
Gr8 news for me I got the bolts out w/o any major issues. I sprayed them every day with Kroil penetrating oil and it seemed to work well. They were hard to get started, but after working aback and forth I finally free them loose. Thanks
Old 02-27-2014, 06:09 PM   #4
motorcritter
motorcritter's Avatar
My experience is that, if Kroil won't get the fastener undone- it's time for the Flame Wrench! Got a pair of studs and nuts soaking on a '35 Plymouth shock absorber. I really don't want to hit it with fire- and, I probably won't have to.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 02-27-2014, 07:04 PM   #5
sambudo
sambudo's Avatar
I also read that a good home remedy was 50/50 ATF/Acetone I didn't get a chance to try it out but very interested. I will mix up a batch for upcoming issues.
Old 02-27-2014, 08:01 PM   #6
bigmac73
bigmac73's Avatar
Amazon.com: OIL OF WINTERGREEN PT: Sports &... Amazon.com: OIL OF WINTERGREEN PT: Sports &...
i have been using this as a rust buster penetrating oil for 20 years in the navy, but dont get it on your face /eyes and groin
Methyl Salicylate
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-27-2014, 08:24 PM   #7
sambudo
sambudo's Avatar
Originally Posted by bigmac73 View Post
Amazon.com: OIL OF WINTERGREEN PT: Sports & Outdoors
Methyl Salicylate
seriously? Good to know. What do they use it for on horses?
Old 02-27-2014, 09:37 PM   #8
bigmac73
bigmac73's Avatar
it is a liniment that physical therapist use as well, same active ingredent stuff in ben gay ect ect, but i buy the stuff from a chemical site so it is just advertised as Methyl Salicylate
Mike
